engine mounts
Started by dazzle53, April 16, 2010, 09:51:25 AM
dazzle53
hi does anyone uprate there engine mounts? ive uprated my gearbox mount already but am still finding alot of twist as it manages to knock the linkage off and seperate the exhaust  :( should i just eplace the front to mounts with standard or uprate?
hardchargin40
Do you know the hardness of the uprated one and where did you get them from, just curious thats all.  Only uprated ones ive ever know where the cup car ones, rocking horse sh1t now.
Depending on hardness, vibration will be an issue, comfort wise on the road.  You shouldn't have too much of a hassle though just replacing with new mounts, yours maybe perished and tired.
dazzle53
the only one ive changed is the gearbox mount from pps
dekerf1996
there have been group buys on uprated rubber mounts made out of poly, usually built around a shore rating of .55 and a couple of sets made at a shore rating of .60. (i did the 3 and last group buy on these)
You could try and find a set of these second hand?? or failing that would suggest new VW ones.
If you really want a set of the poly ones, i might be able to get some made up for you, but they would be really costly, as there is no demand for them anymore, so can't get enough for a group buy together.
has anyone measured the shore rating of standard VW rubbers?
