how much work needed?
Started by oli, March 04, 2010, 04:40:13 PM
oli
hello i wanna drop a g40 lump in my mk2 polo saloon, new to this forum and i wanna get it figured out before i start purchasing things. pretty amateur questions i know but im not afraid. do i need to start hacking the engine bay to bits? whats the deal? talk to me.
oli
vwmk3jon
A G40 engine should slot easy into a mk2 bay. Been done quite afew times iirc.
hi, welcome to the forum.
There's no "hacking" involved, it's all bolt-in stuff.  You'll need (and there may be bits I've forgotten, I'm sure others will add to this):
- engine and all ancillaries such as charger, inlet/exhaust manifolds, alternator, distributor etc...
- engine wiring loom, ECU
- complete fuelling system, i.e. fuel tank, fuel lines, fuel pumps, fuel pump & filter mouting bracket
- not essential but it's best to use a proper G40 gearbox as the ratios are better suited than others but a 5 speed CL box (usually coded 8P) will be a reasonable option, although any 084/085 box will fit
- exhaust system
- depending on the age of the mk2 you might need the handbrake cables from a late mk2 or mk3
- intercooler and all boost pipes
- g40 front brakes
- ignition coil
ideally get a complete crash damaged car, then you know you should have everything
yeah on a mk2 you are right!
benh999
mk1 polo requires some chopping!!!!!!!!! :)
