yes G40 not starting! FIXED!
Started by cheddarcheese, September 03, 2009, 11:22:10 AM
cheddarcheese
Just removed the engine to change the gearbox and then popped it back in its hole connected every thing up and it will not start.
engine turns over.
fuel pumps priming.
spark at the leads.
changed ecu,coil,relays.
checked all earths.
fresh charged battery.
any ideas?
andy
cheddarcheese
iv changed the fuel line input and output it now fires up but really lumpy and will not hold idle any ideas?
iv checked every thing i just don't no what i am missing it all worked fine before removal.
cheddarcheese
#2
i have to give it gas to get it started then it will rev ok high rpm but low down rpm its extremely lumpy and dies? lots of fuel smelling smoke too?
just checked the spark plugs they are very black? changed them any way for spare one's what could of changed from removing the engine i left every thing connected to the engine when i removed it?
i also noticed that the crank senser lead has a slit in the outer rubber but the internal wires are fine?
cheddarcheese
the ht leads are setup correctly. knock senser.
cheddarcheese
fixed! it was the big connector on the fuel rail was the wrong way round i new it would be a simple problem but annoying but fixed and now i am going for a drive haha.
cheers rae for the help
Tommo
