Boost?
Started by Dingle_Polo, August 08, 2009, 05:58:14 PM
Dingle_Polo
where is it going?
well my friend g40 is not geting any boost above 0.3 bar, the car runs fine but it hunting a little.
check for leaks on boost pipes and vacum hoses also if the return valve closes on full throttle which i does. ive alos checked the sive like thing in the bottom of the intercooler which is gd too.
wonderd if any1 had simular problems and could direct me in the right direction.
engine modification:
4 branch
ported throttle bodie and d/w
65mm pulley
gt inlet
stage 4 porting
any help would b great thanks
hardchargin40
vwmk3jon
Am i right in thinking dewedging the throttlebody can have an effect on idle?
dewedging the throttle body shouldn't affect idle unless the holes left over haven't been sealed properly.
Are his charger belts slipping badly?  With that spec you should be seeing almost a bar of boost.
What did you do to check for boost leaks?
Dingle_Polo
well i checked all boost hoses and vacum hoses, used a vacum tester on the small vacum hoses made sure the throttle return valve shuts fully. bit did fined the a/f meter o ring was pissed so remove and replaced but still only boost to 0.5 bar which still aint as much a should be. any suggestions wud be great.
cheers zack
