ptfe spray into charger
Started by g40chris, May 10, 2009, 06:49:14 PM
g40chris
i sprayed some of this into the inlets as advised when running and i noticed that it changed the tone of the engine/charger for a few seconds as if the revs had dropped.
is this normal or could i have a problem somewhere
scotsjohn
Some spray going right through the system into the combustion chambers; normal.
g40chris
rich4130
How long do you guys spray it in? and do you cover the inlet with something else to seal it to the can when you do it?
yeah I used to give it some revs while doing it so the engine doesn't struggle.  I never covered the inlet up or anything, just give it a bit of revs and spray in.  Probably 3 or 4 short sprays for a second or two each.  Don't go spraying tons of the stuff.
cheddarcheese
How often should you spray in to you charger?
PSD used to say every 1000 miles
cheddarcheese
what if its a weekend G thats made to get thrashed and driven hard?
Alexiskayak_7
I've sprayed some ptfe (6 short bursts) i loosed the belts and i rolled with my hand the charger and it was turning slightly hard (i have done the same test before spraying the ptfe when i had the boost return pipes). Has anybody rebuilt a charger that was using ptfe - are they lubricating ok?
