crank pulley issues
Started by g40chris, April 03, 2009, 05:11:16 PM
g40chris
is there an easy way to take off the crank pulley, mine seems to be air gunned on and is getting a right ball ache. any tips of easy ways would be greatly appreciated
you mean the inner one that the cambelt goes round?  I use a steel bar with two holes drilled in, bolt it to the sprocket using the outer pulley bolt holes and then let that hit the ground to hold the crank still and undo the bolt with a breaker bar.
if you just mean the outer pulley then you don't need to touch the centre crank bolt.
to undo the inner pulley bolt i tend to use a chain whip with a bit of old cambelt in the teeth.
usually does it!
but if yr just want to get the outer pulley off (that holds the charger belts) as hayesey says, you just undo the 4 allen bolts
g40chris
yep the outer pulley
aint tried to get it off since my mate tried to get it off 2 years ago
will be doing this 2moro
cheers guys
g40chris
i have had a look at the 4 allen bolts, 2 came out easy enough. the other 2 look as if they have been rounded at the allen end, dont wanna try anymore as i dont wanna make it harder to take these out.
AW TRACKSPORTS FAULT BLOODY COWBOYS
a common thing!  You'll have to hammer torx or spline bits into them.
or hammer a socket over them
g40chris
sorted this now
hammered an allen key into it
pulley wouldnt come off as the bodywork was in the way of the pulley and it was a 6 groove pulley so wider than the usual
i took the engine mount off and dropped the engine down so that the pulley was able to pass the bodywork.
snorted now
alternator pulley tomorrow
Matty!
Just to revive this thread...
Got all 4 bolts off the outer Crank, any tips on getting it off from there? Don't want to be braying stuff it if can be avoided.
I havnt fully tried myself yet as I came on here to check regarding the 19mm centre bolt however thats been answered- thanks.
i use a slide hammer with an L shaped attachement at the end.
Matty!
Tarrrr, will tackle that one tomorrow, cheers.
