Boost return valve setting
Started by G-spot, April 23, 2008, 09:53:30 AM
G-spot
Just out of interest, what do most of you G runner hasve yout BRV set at, ie, do you have it closing at mid throttle, part throttle, full throttle??  I've always run mine so that the BRV doesn't fully close until the throttle butterfly is fully open, but since installing a new block with much better compression and hence better suction I've found that my boost has dropped and I'm hearing the air pushing past the BRV moer than I used too??
Any thought's??  Could I get away with adjusting the valve to close a bit sooner??
Alexiskayak_7
Oh maaan... I just saw the post... Yes i can tell you, i have autodata books. I will post he answear in 4-5 days cuz our store is closed now for easter holidays
