fuel pump has packed up
Started by chasesfc, February 21, 2009, 10:39:01 PM
chasesfc
hi the pump outside the tank by the o/s/r wheel has packed up. what does everyone replace it with as i dont have a spare.
i have seen a facet pump but they say it can not be used on fuel injection cars. has anyone used this on their motor
breadman
Nah, those Facet pumps are fine on cars with carbs but for injection engines you need the proper high pressure Bosch pump. They are a specific pump on multi point injection engines too, make sure you get the right one.
IIRC they're about £140 from the stealers?
yeah that pump pictured is totally unsuitable for a g40.  It's a low pressure pump for carbs.  Although you can use it on a g40 as a stand-alone oil supply pump  :)
