Technical => Engine and Transmission => Topic started by: xrrich on February 11, 2013, 09:45:04 AM
Title: Part numbers ?
Post by: xrrich on February 11, 2013, 09:45:04 AM
Hi just spoke to gsf and they are saying they don't do head gasket kits anymore
Does anyone have a part number because he didn't seen to want to find it
After
head gasket kit
Cambelt
WAterpump
Studs for inlet manifold
Studs for exhaust manifold
Rich
Title: Re: Part numbers ?
Post by: xrrich on February 11, 2013, 09:48:28 AM
And head bolts
Post by: Jezza-7 on February 11, 2013, 09:55:44 AM
None of these any good?
http://www.polog40.co.uk/forum/index.php/topic,3313.0.html
Post by: PeteG40 on February 11, 2013, 10:20:50 AM
g40 head gasket is obsolete at vw
Post by: xrrich on February 11, 2013, 10:56:45 AM
Nope , where do people get them from then
Bartek
Or maxrpm?
Post by: PeteG40 on February 11, 2013, 11:55:16 AM
elring make one
or people use a metal mk4 8v one.
Post by: xrrich on February 11, 2013, 12:11:12 PM
Cheers are BGA any good?
What are you guys using?
Post by: PeteG40 on February 11, 2013, 12:35:56 PM
bga headgasket is listed as for all mk3s incl g40...  so i dont think its right.
however bga g40 spec headbolts are correct 10.9 tensile (not 8.8 as per normal polo headbolts)
Post by: xrrich on February 11, 2013, 03:08:06 PM
After pestering a different gsf they managed to source me a BGA one hopfuly they are decent
Post by: xandyx on February 11, 2013, 03:14:48 PM
Try www.mohlis.de they do sell elring gasket kits.
Post by: PeteG40 on February 11, 2013, 03:51:03 PM
bga ones will be wrong... it'll be a cl gasket
Post by: xrrich on February 11, 2013, 04:46:48 PM
Ahh really whats the difference how can i tell
Rich
Post by: PeteG40 on February 11, 2013, 04:52:49 PM
Well the bga one i've got is listed for NZ/3F and PY - the NZ and PY have two different part numbers on vagcat
(www.vagcat.com)
so it might be ok - but I didn't chance it and mine is still in the packet!
Its a bit like if you go to gsf and get a rocker cover... you get a cl/gt one... which is just rubber.  G40 ones have a steel insert and are much better quality.
Post by: youngprodigys on February 11, 2013, 05:17:27 PM
Just looked up a few bits and found the current VW numbers for the following parts are
Head bolts - 030 103 384 M11x1.5 x98
Headgasket - 030 103 383 R the letter R is the important bit
Exhaust gasket - 030 253 039 A (for a pair)
Inlet manifold gasket - 030 129 717 D
Dizzy oil seal - 030 905 224 (42x4.5mm) + lil bugger 030 905 261
Camshaft oil seal - 030 103 085 A (47x10mm)
Thermostat housing seal - 030 121 119
Cambelt - 052 109 119 (special note PY 002 177)
Waterpump - theres 2 types - square tooth and round tooth cambelt
052121 005 AX (special note PY 002 177)
052121 005 LX (special note PY 002 178)
i dont know which is correct - i have a brand new in the box water pump in my garage with my 1W build but i cant get to it just yet to confirm which numbers which
the seal for the pump on its own is
030 121 043 B (4mm)
030 121 043 A (5mm) which i think its for a worn or corroded leaking block
Throttle body seal - 030 133 073 A
Exhaust manifold studs  - N044 410 4 M8x28
Inlet manifold studs - N044 408 2
KiZ
Post by: xrrich on February 15, 2013, 05:28:00 PM
so i got the head gasket kit, the kit said PY on the front but the gasket inside was wrapped as well and says
engine code FY?
It came with G40 rocker gasket
G40 rocker bolt rubbers
and looks like its got a metal insert in the gasket,
Is it good to use?
rich
Post by: PeteG40 on February 16, 2013, 07:35:32 AM
Is the rocker wibbly rubber or hard? And is the gasket listed for just py or others too
Post by: xrrich on February 16, 2013, 09:43:01 AM
It is hard like if I was to bend it it would kink and stay rigid
All it says is engine code FY ?
Post by: PeteG40 on February 16, 2013, 01:38:53 PM
That's a proper g rocker gasket then
Post by: xrrich on February 18, 2013, 09:39:48 PM
awesome! cheers pete
Post by: z3i on February 18, 2013, 09:59:28 PM
How much was it from gsf? i need to order one tommorow? did you just give them your reg or have to specify for the metal/rubber rocker cover gasket? cheers mate
Post by: xrrich on February 18, 2013, 10:31:26 PM
They had a bit of trouble getting it in but after many phonecalls they got one in for me, luckily i know someone that works there so he put in more of an effort lol.
I bought the whole kit which was 42£ but i get discount so not sure how much it is normally, Just tell them your reg
Looking at the receipt is says
GSFno. SC422
Ref2. HK3542
