Technical => Chassis & Braking => Topic started by: Jezza-7 on April 20, 2011, 11:00:11 PM
Title: 14" 8J
Post by: Jezza-7 on April 20, 2011, 11:00:11 PM
Been looking into steffan bcw's 14x7,5/ 14x8j ET 15 and was wondering if you would get much clearance or tyre rub?
Also would you need spacers?
Have seen a mk3 polo in the search for "steffan" that had them fitted.
Anyone know the owner?
http://www.polog40.co.uk/forum/index.php/topic,1137.0.html
Title: Re: 14" 8J
Post by: AlexG40 on April 20, 2011, 11:03:49 PM
You'll find that 7.5 on the front sticks out a bit. Whether it rubs or not will depend on lows and tyre choice.  8's on the back will rub with 195/45 on but will be minimal unless you have it on it's arse.
Title: Re: 14" 8J
Post by: Jezza-7 on April 20, 2011, 11:08:39 PM
i will be using a 40/60 h&r cup kit soon.
Most tyre size's i have seen people use with these are 195/45. Would probably stick with them.
Would a tyre size of 185/50 be better?
Title: Re: 14" 8J
Post by: Jezza-7 on April 20, 2011, 11:09:15 PM
Think i just answered that myself lol. That would be worse, right?
Title: Re: 14" 8J
Post by: AlexG40 on April 20, 2011, 11:18:55 PM
185/50 is a higher profile but will have a little more stretch. At 60/40 I think you'll be ok with 195/45's although they seem to cost a shit load more from memory.
You're biggest issue will be 7.5 ET15 on the front.
This pic shows my G with 8j et 15 on the back and 7j et 20 on the front. Both with 195/45.  7.5j et 15 is going to stick out another 20mm (ish)
(http://farm6.static.flickr.com/5307/5638499639_6ab628e0cd_z.jpg)
Title: Re: 14" 8J
Post by: Jezza-7 on April 21, 2011, 09:41:02 AM
Looks very nice.
So because there et 15 they will be mounted slightly further out and the width being wider will make them stick out a little further, i see.
So you wouldn't need spacers as there already far enough out.
Picture helps understand it better, well did for me.
(http://i443.photobucket.com/albums/qq157/jezza-3/wheel_offset_diagram.jpg)
Title: Re: 14" 8J
Post by: AlexG40 on April 21, 2011, 03:11:35 PM
Yep, basically you'll be further out because of both. The other thing to bear in mind is that my arches are fully rolled and it still rubbed a bit at the back.
If you did a diagram based on the pic you have you could work out the exact dimensions for my wheels and your proposed ones, should give you an accurate idea.
Title: Re: 14" 8J
Post by: Etches on April 21, 2011, 05:31:52 PM
I had some 14 x 8  , borbet ts on. Rolled my arches a fair bit and was lowerd 60 , scrubbed on some bumps but not many.
Title: Re: 14" 8J
Post by: Puncharado on April 21, 2011, 05:43:18 PM
Easy rule of thumb is the lower the offset the more they stick out. You need a lower offset than standard with wider wheels to keep the inside edge away from the suspension, this is not such a problem with a height adjustable set-up as they use smaller diameter springs. The downside is arch scrubbing which you're already aware of.
