Technical => Engine and Transmission => Topic started by: djtez on September 05, 2008, 09:48:39 PM
Title: headgasket overhaul
Post by: djtez on September 05, 2008, 09:48:39 PM
My car just the other day encountered a problem (head gasket)
i knew all the sypthoms and proceeded yesterday to strip the head off..
i took out the cam first which had marking on the dizzy end (bp 27 ohy g40) and few other figures..
not all clear but i will try take a foto. is this a Standard cam?!!
i am very interested and concerned about the gasket replacment..
wat gasket should i buy.. i didn't think high compression was good for the g40?
im worried about skimmin the head? can i get a thicker gasket?
some one mentions on clubpolo about a metal gasket
Title: Re: headgasket overhaul
Post by: PeteG40 on September 05, 2008, 10:25:43 PM
see my post in yr other post
Title: Re: Re: headgasket overhaul
Post by: hayesey on September 05, 2008, 10:43:17 PM
I guess that "someone" would be me :)
I wouldn't worry in the slightest about skimming the head reducing compression ratio.  The g40 has the combustion chamber in the pistons with a pretty much flat head so skimming the head makes such a small difference to compression ratio you needn't worry about it, as I said on clubpolo.
The metal gasket is from a mk4 polo 8v engine and will raise compression if you want it to be higher.
Title: Re: Re: Re: headgasket overhaul
Post by: djtez on September 05, 2008, 10:47:18 PM
can i have a part number for this
is this a 1.3 cl out the 6n polo?
this my best option.. i have noticed a post on this site about a psd gasket?
not much difference no ?
Title: Re: Re: Re: Re: headgasket overhaul
Post by: hayesey on September 05, 2008, 11:08:13 PM
it's the one from the MPI engines, 1.4, 1.6.  Look for the one for AEX engine code on GSF website.
Title: Re: Re: Re: Re: Re: headgasket overhaul
Post by: Rob on September 06, 2008, 11:49:11 AM
GSF part number - 030-103-383AH is what i have used
HTH
Title: Re: Re: Re: Re: Re: Re: headgasket overhaul
Post by: djtez on September 09, 2008, 12:50:04 PM
ok thanks , im not argueing against your knowledge but how does a 1.4 or 1.6 gasket fit on a 1.3 ??
are the water channels still the same ?
Title: Re: Re: Re: Re: Re: Re: Re: headgasket overhaul
Post by: PeteG40 on September 09, 2008, 12:56:37 PM
yes they are!
Title: Re: Re: Re: Re: Re: Re: Re: Re: headgasket overhaul
Post by: djtez on September 09, 2008, 01:13:17 PM
ahh thank you.. im ordering the parts RIGHT NOW lol :D excited but im stuck lol
i've got a head gasket .. rocker gasket.. sump gasket(i need one)
inlet and exhaust..
which valve stem seal do i need!!
is the one (all engine fitted with 6mm valves) ? wat else ... i cant think.. brain.. freeze ahhhh
Title: Re: Re: Re: Re: Re: Re: Re: Re: Re: headgasket overhaul
Post by: djtez on September 09, 2008, 01:18:12 PM
im confused with findin a camshaft seal? my one when i took the cam out the little spring that i assume holds the seal tight to the cam wasen't holding in place..
so ill just replace it
Title: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: headgasket overhaul
Post by: PeteG40 on September 09, 2008, 01:43:56 PM
cam/crank oil seal are teh same bit...      you also need 10x headbolts
Title: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: headgasket overhaul
Post by: djtez on September 09, 2008, 02:01:15 PM
Part Number      Description      Fitment      Price(£)      Quantity      Delete
11028    VALVE COVER GASKET    PO 1.3 75 BHP 10/90 >7/94      3.75    1    Delete
11805    INLET MANIFOLD GASKET    PO G40 10/90 >7/94      2.50    1    Delete
11830    EXHAUST MANIFOLD GASKET (2 required per car)    PO 0.9-1.3      3.00    2    Delete
11133B    CYLINDER HEAD GASKET    PO 1.4 / 1.6 ADX/AEA/AEX Engines 94>      15.60    1    Delete
11615    SUMP GASKET    PO 1.3 1/77 >7/95      4.85    1    Delete
14414    EXHAUST VALVE    PO G40 10/90 >7/94      5.60    4    Delete
01161    CYL.HEAD BOLT+WASHER-11mm    PO G40 10/90 >7/94      1.00    10    Delete
11740    OIL SEAL-CAM/INT/CRANK BQ    PO 1.3 75 BHP 9/82 >9/90      5.90    1    Delete
TOTAL(exc. VAT & Delivery)       £ 71.00
Delivery(UK)     Free Delivery
VAT      £ 12.43
TOTAL      £ 83.43
this all good or am i missing something
Title: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: headgasket overhaul
Post by: djtez on September 09, 2008, 03:28:54 PM
which dizzy cap is for the g ??
https://secure.gsfcarparts.com/shop/results.asp
plus theres two spark plugs
w5dtc and w5dpo i;ve heard of the second one but dpo is 10. a plug and the other like 3 or summin..
Title: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: headgasket overhaul
Post by: PeteG40 on September 09, 2008, 03:29:33 PM
link no worky... ring em up  = would be easier!
Title: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: headgasket overhaul
Post by: djtez on September 09, 2008, 04:09:02 PM
*  Click here to perform a new search.
18723    SEAL RING-INJECTOR LARGE    General Use Most Late Inj. 85>      0.60    4    Delete
28212    EXHAUST DOWN PIPE GASKET    PO 1.3 75 BHP All      1.80    1    Delete
MMW712/52    OIL FILTER    PO 1.3 Inc. G40 10/90 >7/95      3.25    1    Delete
18726    SEAL RING-INJECTOR SMALL    General Use Most Late Inj. 85>      0.60    4    Delete
92218    IGNITION ROTOR ARM    PO G40 10/90 >7/94      3.95    1    Delete
92133    DISTRIBUTOR CAP    G2 1.3 5/90 >7/92 Bosch Type -Shroud      4.95    1    Delete
TOTAL(exc. VAT & Delivery)       £ 67.35
VAT      £ 11.79
TOTAL      £ 79.14
just ordered this..
cant think anything else... gsf dont do the studs.. foned them up
