Technical => Engine and Transmission => Topic started by: xrrich on June 17, 2014, 05:04:24 PM
Title: Advice- water ways in block corrosion- weld and skim?
Post by: xrrich on June 17, 2014, 05:04:24 PM
Hi guys
Shall I get the water ways welded and re skimmed as 1 in paticular seems to be very close to the sealing ring
(http://i32.photobucket.com/albums/d30/laluk_22/Mobile%20Uploads/5E14BA41-15E7-433C-8A7F-1634786ABEC7_zpsqmgnwo1w.jpg) (http://s32.photobucket.com/user/laluk_22/media/Mobile%20Uploads/5E14BA41-15E7-433C-8A7F-1634786ABEC7_zpsqmgnwo1w.jpg.html)
(http://i32.photobucket.com/albums/d30/laluk_22/Mobile%20Uploads/C39EC160-73F2-40EF-9232-296A4B929DE3_zpsxy8lw73c.jpg) (http://s32.photobucket.com/user/laluk_22/media/Mobile%20Uploads/C39EC160-73F2-40EF-9232-296A4B929DE3_zpsxy8lw73c.jpg.html)
Rich
Title: Re: Advice- water ways in block corrosion- weld and skim?
Post by: Robin on June 17, 2014, 09:34:47 PM
They 1341 pistons? If so then you will be fine - lots of us are running 1341cc without issues.
Post by: xrrich on June 17, 2014, 09:41:00 PM
Hey thanks for the reply
Yeah there are 1341
Just thought the corrosion on the one pictured was excessive, giving little sealing area?
Rich
Post by: PeteG40 on June 17, 2014, 10:54:38 PM
id ask at an engine shop tbh
Post by: xrrich on June 18, 2014, 06:08:25 AM
Thank Pete yeah will do
Last thing I want is head gasket problems once I've built it
Post by: Yoof on June 18, 2014, 07:47:58 AM
I would:
- measure depth of pitting
- calculate CR with block decked to remove pitting
- if too high use stock composite gasket (not 6n metal item)
- Swear, remove pistons, strip block and get it machined.
You could do the opposite and weld it up and surface grind the face, but I'd have thought a new block would be cheaper.
