Technical => Engine and Transmission => Topic started by: xrrich on June 17, 2014, 05:04:24 pm
Hi guys
Shall I get the water ways welded and re skimmed as 1 in paticular seems to be very close to the sealing ring
(http://i32.photobucket.com/albums/d30/laluk_22/Mobile%20Uploads/5E14BA41-15E7-433C-8A7F-1634786ABEC7_zpsqmgnwo1w.jpg) (http://s32.photobucket.com/user/laluk_22/media/Mobile%20Uploads/5E14BA41-15E7-433C-8A7F-1634786ABEC7_zpsqmgnwo1w.jpg.html)
(http://i32.photobucket.com/albums/d30/laluk_22/Mobile%20Uploads/C39EC160-73F2-40EF-9232-296A4B929DE3_zpsxy8lw73c.jpg) (http://s32.photobucket.com/user/laluk_22/media/Mobile%20Uploads/C39EC160-73F2-40EF-9232-296A4B929DE3_zpsxy8lw73c.jpg.html)
Rich
They 1341 pistons? If so then you will be fine - lots of us are running 1341cc without issues.
Hey thanks for the reply
Yeah there are 1341
Just thought the corrosion on the one pictured was excessive, giving little sealing area?
Rich
id ask at an engine shop tbh
Thank Pete yeah will do
Last thing I want is head gasket problems once I've built it
I would:
- measure depth of pitting
- calculate CR with block decked to remove pitting
- if too high use stock composite gasket (not 6n metal item)
- Swear, remove pistons, strip block and get it machined.
You could do the opposite and weld it up and surface grind the face, but I'd have thought a new block would be cheaper.
