Author Topic: G40 quiz - for geeks  (Read 7337 times)
« on: April 02, 2009, 03:07:17 pm »
Answers tomorrow
1. What bhp are g40s as standard?
2. What tyre size are the standard g40 tyre?
3. Name one brand of original g40 tyre (iirc there are 2!)
4. What what name to vw give to the interior seat pattern on a g40?
5. G40s had a recall - which part of the car was this for?
6. Name the two makes of glass used on g40s.
7. How do stock g40 mirrors differ from other late mk2/3 standard mirrors?
8. What size thread are g40 brake bleed nipples?
9. What manufacturer did vw use for the majority of the charger bearings?
10. Which bolt - strangely - is the one on the car with an 11mm head?
11. What size bore are rear cylinders on a g40 (in mm)?
12. What three colours were standard on the g40 range?
13. What is the offset, ET, of a standard polo g40 rim.
14. What are the recommended tyres pressures at half load in psi?
15. What ampage is the stock g40 alternator?
any one gets em all right is very sad but first one may earn a g40 sticker if i can find one!
Re: G40 quiz - for geeks
« Reply #1 on: April 02, 2009, 03:26:31 pm »
having a slow day at work are we?  8)
Offline vwmk3jon
« Reply #2 on: April 02, 2009, 03:40:54 pm »
I'm not the biggest geek on here (am i Pete? lol) but i'll have a go!
1. What bhp are g40s as standard? 113BHP
2. What tyre size are the standard g40 tyre? 185/60/13?
3. Name one brand of original g40 tyre (iirc there are 2!) goodyear?
4. What what name to vw give to the interior seat pattern on a g40? tartan
5. G40s had a recall - which part of the car was this for? well it wasnt the brakes! lol. No idea.
6. Name the two makes of glass used on g40s. green and not green
12. What three colours were standard on the g40 range? Black red and white?
13. What is the offset, ET, of a standard polo g40 rim. pass
14. What are the recommended tyres pressures at half load in psi? 25psi
15. What ampage is the stock g40 alternator? 65amp
« Reply #3 on: April 02, 2009, 03:48:19 pm »
vwmk3jon - 3 correct!
Offline GTG40
« Reply #4 on: April 02, 2009, 03:48:38 pm »
9. What manufacturer did vw use for the majority of the charger bearings? FAG. well thats what where in mine
10. Which bolt - strangely - is the one on the car with an 11mm head? Cam shaft bolts, just done my cam recently
Offline Max
« Reply #5 on: April 02, 2009, 03:51:34 pm »
Here it goes, nearly all guesses haha
2. What tyre size are the standard g40 tyre? 175/60/13
3. Name one brand of original g40 tyre (iirc there are 2!) Continental and Michelin
4. What what name to vw give to the interior seat pattern on a g40? Le Mans
5. G40s had a recall - which part of the car was this for? Pass
6. Name the two makes of glass used on g40s. Pass
7. How do stock g40 mirrors differ from other late mk2/3 standard mirrors? Pass
8. What size thread are g40 brake bleed nipples? 8mm
9. What manufacturer did vw use for the majority of the charger bearings? Pass
10. Which bolt - strangely - is the one on the car with an 11mm head? Pass
11. What size bore are rear cylinders on a g40 (in mm)? Pass
12. What three colours were standard on the g40 range? Grey, Red and Green
13. What is the offset, ET, of a standard polo g40 rim. 13x5.5 ET33
14. What are the recommended tyres pressures at half load in psi? 30PSI
Offline samg40
  • Take.... on.... me....
« Reply #6 on: April 02, 2009, 04:02:59 pm »
Wow, how the nights whizz past at your house eh!
To answer some of the ones that people havent got right yet. The difference in mirrors is three brackets to hold them on instead of two. The two makes of glass are Sekurit and Secursiv. I'd say the colours are Alpine white, Tornado Red and cant remember the proper name of the other one. One of the tyres was Michelin MXV 2's I believe too.
Wow, after that I think I need to look at boobs or something, seriously sad.
« Reply #7 on: April 02, 2009, 04:30:43 pm »
Quote
 :D :D :D :D
I bet pete was thinking about the flywheel bottom cover bolt that goes on the gearbox as the 11mm bolt but the camshaft bearings are also 11mm!
« Reply #8 on: April 02, 2009, 04:35:16 pm »
camshaft covers are nuts - not bolts!!!
i have to do something to show my worthy place as club leader!
sam - as for nights whizzing past - ye, i'm working on my car(s) its taken me same time to fit an engine conversion (with engine repair) as its taken you to do a corrado rear wheel bearing!!!  I know your past times are x box and sitting on yr couch with yr hand down yr pants!
« Reply #9 on: April 02, 2009, 04:40:01 pm »
Quote
bah a mere technicality.  Anyway, I was right!  do I win a pint of mild for that?
Offline samg40
« Reply #10 on: April 02, 2009, 04:47:41 pm »
I dont remember voting you as club leader do you Mr Hayes!
And I've done two wheel bearings actually and I'm sure you've still found time to stick your hand down your pants whilst on your laptop staring at oily bits of cars!  :P ;) ;D
Offline GTG40
« Reply #11 on: April 02, 2009, 04:58:10 pm »
Now now ladies its only a quiz   :D
Lets not bicker on who's better than who
« Last Edit: April 02, 2009, 05:03:27 pm by GTG40 »
« Reply #12 on: April 02, 2009, 04:59:56 pm »
good point actually, is Pete starting some kind of military coo to take over?
Seems to be something with Corrado owners, my mate martin has spent what must be getting on for 8 months now doing a gearbox swap on his VR.
Offline Robin
  • 194bhp - 1341 Turbo
« Reply #13 on: April 02, 2009, 05:03:04 pm »
1. What bhp are g40s as standard? - 113bhp
2. What tyre size are the standard g40 tyre? - 185/60/13
3. Name one brand of original g40 tyre (iirc there are 2!) - pirelli
4. What what name to vw give to the interior seat pattern on a g40? - le mans
5. G40s had a recall - which part of the car was this for? - coil
6. Name the two makes of glass used on g40s. - pilkington
7. How do stock g40 mirrors differ from other late mk2/3 standard mirrors? - adjustable inside
8. What size thread are g40 brake bleed nipples? - M10
9. What manufacturer did vw use for the majority of the charger bearings? - FAG
10. Which bolt - strangely - is the one on the car with an 11mm head? - gearbox cover plate at the bottom
11. What size bore are rear cylinders on a g40 (in mm)?  - 23mm
12. What three colours were standard on the g40 range? - black red white
13. What is the offset, ET, of a standard polo g40 rim. - ET38
14. What are the recommended tyres pressures at half load in psi? - 26psi
15. What ampage is the stock g40 alternator? - 65
sickooooooooooooooooo
me and yoof's answers
all the wrong ones are mine!
Offline vwmk3jon
« Reply #14 on: April 02, 2009, 06:14:54 pm »
3 hahaha.
Let it be known - i know fuck all about the car i drive!!!!
