1. What bhp are g40s as standard? 113bhp
2. What tyre size are the standard g40 tyre? 175/60/R13
3. Name one brand of original g40 tyre (iirc there are 2!) Yokos
4. What what name to vw give to the interior seat pattern on a g40? Le mans
5. G40s had a recall - which part of the car was this for? mastercylinder?
6. Name the two makes of glass used on g40s. No idea
7. How do stock g40 mirrors differ from other late mk2/3 standard mirrors? pass
8. What size thread are g40 brake bleed nipples? m8
9. What manufacturer did vw use for the majority of the charger bearings? pass
10. Which bolt - strangely - is the one on the car with an 11mm head? camshaft
11. What size bore are rear cylinders on a g40 (in mm)? 25mm
12. What three colours were standard on the g40 range? alpine white, tornado red, black
13. What is the offset, ET, of a standard polo g40 rim. et-38
14. What are the recommended tyres pressures at half load in psi? 25psi
15. What ampage is the stock g40 alternator? 65 amps
Some guesses there ha ha not so im not such a geek after all! Try telling my girlfriend that though, she thinks that im having an affair with the car..
