Author Topic: stuck already haha (N)  (Read 4302 times)
Offline TomG401991
« on: January 26, 2009, 08:23:24 pm »
how the hell do you remove the front slam panel and or attaching panels ? ? ?
Re: stuck already haha (N)
« Reply #1 on: January 26, 2009, 08:42:11 pm »
the front slam panel is welded on.  You'll need a spot weld drill or use an angle grinder to grind through the top part of the metal where the spot welds are.  Obviously you'll have to replace the panel with a new one after this!  I riveted mine on so it can be removed easily to take the engine out.
what do you mean by "attaching panels"?
Offline TomG401991
« Reply #2 on: January 26, 2009, 09:07:54 pm »
well i thought bolts along the top of slam panel and the two closest bolts on the wing nooo so i am goin to have to cut and weld (N) dam !!
« Reply #3 on: January 26, 2009, 09:51:41 pm »
yeah you'll need to take the wings off first too.  Right ball-ache really
Offline TomG401991
« Reply #4 on: January 26, 2009, 10:37:06 pm »
fuck looked over the engine the other day thought hmm dont look to bad
proved wrong ! ! might check in a haynes to see what they say :P
cheers for your help though mate (Y)
Offline TomG401991
« Reply #5 on: January 28, 2009, 11:39:02 pm »
hahaaa sucsess ;D
managed to get the rad/cowling/fan and charger pip off without removing the slam panel
well chuffed
« Reply #6 on: January 29, 2009, 09:42:47 am »
oh right, yeah you can get all that out without removing the slam panel, the only reason to remove the slam panel is to replace it.  Glad you are sorted  8)
