Author Topic: Rear coolant pipe to block gasket  (Read 2959 times)
Offline Robin
  • 194bhp - 1341 Turbo
« on: January 10, 2009, 05:37:38 pm »
I am trying to find a gasket for the rear coolant pipe which bolts onto the block and water pump, its the pipe which has the ISV sitting on.
I can't seem to find it on ETKA as it comes up as a round o ring seal!
Does ECP or GSF sell them?
i would use gasket sealant but the surface of the pipe flange is not flat whatsoever!
Re: Rear coolant pipe to block gasket
« Reply #1 on: January 10, 2009, 06:23:53 pm »
common issue - its from a mk2!!!
« Reply #2 on: January 10, 2009, 06:27:07 pm »
yeah if you buy a new one then it'll be a mk2 gasket.  I just use hymolar on mine, I know you prefer to buy proper vag stuff though.  If it's not flat then the old gasket is probably still on there, scrape it off with a sharp chisel blade.  If both faces aren't flat you've got no chance of it sealing with a paper gasket.  I honestly think hymolar is better for it anyway.
Offline supercharged spaniel
  • GRRRRRRR
« Reply #3 on: January 10, 2009, 06:55:43 pm »
i have two bolt on type gasket ones in my glove box..about a quid each..ill get the part number tomorrow for you robin...mine is weeping very slightly so ive been to change it..
Offline Robin
« Reply #4 on: January 10, 2009, 07:30:22 pm »
nah there is certainly no old gasket on it, i'll take the pipe to work and get them to face it off on a milling machine.
Offline AlexG40
« Reply #5 on: January 10, 2009, 09:16:35 pm »
I used two of the paper gaskets stuck together with sealant after the first one leaked on its own. Never leaked since.
