Rear coolant pipe to block gasket
Started by Robin, January 10, 2009, 05:37:38 PM
Robin
I am trying to find a gasket for the rear coolant pipe which bolts onto the block and water pump, its the pipe which has the ISV sitting on.
I can't seem to find it on ETKA as it comes up as a round o ring seal!
Does ECP or GSF sell them?
i would use gasket sealant but the surface of the pipe flange is not flat whatsoever!
yeah if you buy a new one then it'll be a mk2 gasket.  I just use hymolar on mine, I know you prefer to buy proper vag stuff though.  If it's not flat then the old gasket is probably still on there, scrape it off with a sharp chisel blade.  If both faces aren't flat you've got no chance of it sealing with a paper gasket.  I honestly think hymolar is better for it anyway.
supercharged spaniel
i have two bolt on type gasket ones in my glove box..about a quid each..ill get the part number tomorrow for you robin...mine is weeping very slightly so ive been to change it..
Robin
Quote from: hayesey on January 10, 2009, 06:27:07 PM
nah there is certainly no old gasket on it, i'll take the pipe to work and get them to face it off on a milling machine.
AlexG40
I used two of the paper gaskets stuck together with sealant after the first one leaked on its own. Never leaked since.
