Author Topic: what do thease plugs do ?  (Read 3254 times)
Offline rochey88
« on: October 10, 2010, 02:12:01 pm »
what do thease 4 plugs do?? my temp guage has decided it wants to top working??
but i need to know what thease 4 plugs 2........... 2 on the thermostat and the 2 single pin connectors on the head
Offline Alexiskayak_7
Re: what do thease plugs do ?
« Reply #1 on: October 10, 2010, 02:41:29 pm »
At the firts pic:
Black: Water temperature sensor (gauge sender)
Blue: Water temperature sensor (ECU signal)
The two ones at the 2nd pic are oil pressure switches
The right one (i think) is for the oil buzzer
« Reply #2 on: October 10, 2010, 03:34:42 pm »
that's the wrong black sensor, it should be a two pin one like the blue one (except black!)
Offline rochey88
« Reply #3 on: October 10, 2010, 03:37:54 pm »
but my guage worked before? lol think i should change it ??
« Reply #4 on: October 10, 2010, 03:46:43 pm »
it's definitely not the right type, I'd change it anyway.  What does the plug look like? Can't see how the standard one would fit.
« Reply #5 on: October 10, 2010, 04:57:58 pm »
Yeah... Hayesey is right... It should be a 2 pin... I mentioned that before, but i wasn't sure, if i was right...
Don't you see that you can not plug it into the wiring?
Offline rochey88
« Reply #6 on: October 10, 2010, 05:08:17 pm »
thats odd the loom has that 4 pin plug on the end ?? ??? ??? wheres the bet place to get both them plugs from?
Offline cheys03
« Reply #7 on: October 10, 2010, 05:53:34 pm »
Is the car a conversion or genuine g40?
If a conversion, has it has other, later VAG engines in such as an AFH or 1.6L? That would be a possible reason for the adapted loom.
« Reply #8 on: October 10, 2010, 05:57:00 pm »
possible someone has cut the original connector off but it seems an odd thing to do. Is this engine in a 6n polo or something?
Offline hardchargin40
  • Older, Wiser, Greyer.
    • The Roadster.net
« Reply #9 on: October 11, 2010, 09:36:39 am »
Why does it look like you've a pink gearbox? :D
