Im thinking about putting my g40 into a mk2 loon that I found. but someone pointed out to me that it indeed doesnt have a servo. So if i put the lump into it and blank off the end of the big black vacuum pipe that goes into the servo in a mk3, what do I do with the small white vacuum lines that go into the fuel pressure reg and ecu map sensor?? can I leave them attached to that big pipe still because they will still get a vacuum from it? or do I need to get a vacuum feed from elsewhere??
thanks
