The Advantages of Synthetic Oils over Mineral oils
Started by oilman, June 21, 2013, 09:27:06 AM
oilman
Extended oil drain periods
Better wear protection and therefore extended engine life
Most synthetics give better MPG
They flow better when cold and are more thermally stable when hot
Surface-active meaning a thin layer of oil on the surfaces at all times (in ester based oils)
How Synthetic oils Achieve these Benefits
Stable Basestocks
Synthetic oils are designed from pure, uniform synthetic basestocks, they contain no contaminants or
unstable molecules which are prone to thermal and oxidative break down.
Because of their uniform molecular structure, synthetic lubricants operate with less internal and
external friction than petroleum oils which have a non-uniform molecular structure.
The result is better heat control, and less heat means less stress to the lubricant.
Higher Percentage of Basestock
Synthetic oils contain a higher percentage of lubricant basestock than petroleum oils do.
This is because multi-viscosity oils need a great deal of pour point depressant and viscosity improvers
to operate as a multigrade.
The basestocks actually do most of the lubricating. More basestocks mean a longer oil life.
Additives Used Up More Slowly
Petroleum basestocks are much more prone to oxidation than synthetic oils. Oxidation inhibitors are
needed in greater quantities in petroleum oils as they are used up more quickly.
Synthetic oils do oxidize, but at a much slower rate therefore oxidation inhibiting additives are used up
more slowly.
Synthetic oils provide for better ring seal than petroleum oils do. This minimizes blow-by and reduces
contamination by combustion by-products. As a result, corrosion inhibiting additives have less work to
do and will last much longer in a synthetic oil.
Excellent Heat Tolerance
Synthetics are simply more tolerant to extreme heat than petroleum oils are. When heat builds up
within an engine, petroleum oils quickly begin to burn off. They are more volatile. The lighter
molecules within petroleum oils turn to gas and what's left are the large molecules that are harder to
pump.
Synthetics have far more resistance as they are more thermally stable to begin with and can take
higher temperatures for longer periods without losing viscosity.
Heat Reduction
One of the major factors affecting engine life is component wear and/or failure, which is often the
result of high temperature operation. The uniformly smooth molecular structure of synthetic oils gives
them a much lower coefficient friction (they slip more easily over one another causing less friction)
than petroleum oils.
Less friction means less heat and heat is a major contributor to engine component wear and failure,
synthetic oils significantly reduce these two detrimental effects.
Since each molecule in a synthetic oil is of uniform size, each is equally likely to touch a component
surface at any given time, thus moving a certain amount of heat into the oil stream and away from the
component. This makes synthetic oils far superior heat transfer agents than conventional petroleum
oils.
Greater Film Strength
Petroleum motor oils have very low film strength in comparison to synthetics. The film strength of a
lubricant refers to it's ability to maintain a film of lubricant between two objects when extreme pressure
and heat are applied.
Synthetic oils will typically have a film strength of 5 to 10 times higher than petroleum oils of
comparable viscosity.
Even though heavier weight oils typically have higher film strength than lighter weight oils, an sae 30
or 40 synthetic will typically have a higher film strength than an sae 50 or sae 60 petroleum oil.
A lighter grade synthetic can still maintain proper lubricity and reduce the chance of metal to metal
contact. This means that you can use oils that provide far better fuel efficiency and cold weather
protection without sacrificing engine protection under high temperature, high load conditions.
Obviously, this is a big plus, because you can greatly reduce both cold temperature start-up wear and
high temperature/high load engine wear using a low viscosity oil.
Engine Deposit Reduction
Petroleum oils tend to leave sludge, varnish and deposits behind after thermal and oxidative break
down. They're better than they used to be, but it still occurs.
Deposit build-up leads to a significant reduction in engine performance and engine life as well as
increasing the chance of costly repairs.
Synthetic oils have far superior thermal and oxidative stability and they leave engines virtually varnish,
deposit and sludge-free.
Better Cold Temperature Fluidity
Synthetic oils do not contain the paraffins or other waxes which dramatically thicken petroleum oils
during cold weather. As a result, they tend to flow much better during cold temperature starts and
begin lubricating an engine almost immediately. This leads to significant engine wear reduction, and,
therefore, longer engine life.
Improved Fuel Economy
Because of their uniform molecular structure, synthetic oils are tremendous friction reducers. Less
friction leads to increased fuel economy and improved engine performance.
This means that more energy released from the combustion process can be transferred directly to the
wheels due to the lower friction. Acceleration is more responsive and more powerful, using less fuel in
the process.
In a petroleum oil, lighter molecules tend to boil off easily, leaving behind much heavier molecules
which are difficult to pump. The engine loses more energy pumping these heavy molecules than if it
were pumping lighter ones.
Since synthetic oils have more uniform molecules, fewer of these molecules tend to boil off and when
they do, the molecules which are left are of the same size and pumpability is not affected.
Synthetics are better and in many ways, they are basically better by design as they are created by
chemists in laboratories for a specific purpose, rather than being modified from something that came
out of the ground to be as good as they can for a purpose.
Tim
z3i
Thanks for this mate, what oil do you recommend for a g40 then? To cope with the oil fed supercharger stresses too?
ive always used vw approved qauntum 10w40 semi synthetic, and its only £20 for 5 litres
any better price on that? Thanks
oilman
If your budget is £20, then you are looking at a 10w-40 semi as the best option, but I would say it's worth spending a little more and going for a 5w-40 synthetic. Something like the Fuchs Supersyn is just over £20 with your members discount.
http://www.opieoils.co.uk/c-656-5w-40.aspx
Out of those, the best ones are the Fuchs/Silkolene Pro S, Millers CFS/CFS NT, Motul 300V, Redline and Gulf Competition. The Motul 8100 X-Cess, Millers XFS, Fuchs GT1 XTL/Supersyn, Gulf Formula G, Shell Helix and Mobil Super 3000 are good, cheaper alternatives.
Tim
z3i
Your saying fully synthetic is better over semi?
Ok thanks for that, and what do you recommend for top of the range?
Car is used for commuting so is driven when not fully warm and the thrashed, track abuse now and again
how often do you recommend changes?
thanks again
oilman
Hi
Yes, a full synthetic is better than a semi and a 5w will give better cold start protection than a 10w, so will help out, especially with the commuting.
How many miles do you cover in a year? What's the standard service interval on those?
Tim
z3i
Quote from: oilman on June 21, 2013, 11:46:01 AM
Hi
Tim
every 10k oil filter and oil but i do mine much sooner. 5w 40 fully synthetic? Whats the benifit of 5w 50 over 5 w 40? Fully synthetic
i always worry about full syn as it looks so runny, definitly be ok for the delicate charger bearings?
um probably 15k a year mainly commuting but, track day thrashes and long road trips to switzerland etc, so she does have a hard life
thanks bud
oilman
Hi
There is no advantage in a 50 over a 40, unless the car needs a 50 rather than a 40.
The right grade of synthetic (5w-40 or 10w-40) will give better protection than a mineral based oil. Oil is supposed to be runny, you need it to flow well to lubricate properly. Okay, too thin will lead to reduced protection, but a 5w-40 or 10w-40 will be fine. If you're doing 15k a year, changing a synthetic twice will be fine.
Tim
z3i
How do you rate the silkolene 5w40 pro s fully synthetic? Tempted by it with 20 percent off
also any chance of getting some motul rbf race fluid, enough to bleed my entire system through or something just as good with a really high boiling point
many thanks taylor
Tim,
What oil would you recommend for the standalone oil supply for the supercharger?
Bearing in mind it uses a fuel pump running approx 7psi.
Most people run thin oils like compressor oil and some run 0W10 oils, are these ok to run?
Also operating temps be seem to see 45 degress.
oilman
Quote from: z3i on June 21, 2013, 07:23:57 PM
many thanks taylor
Hi Taylor
The Pro S is ideal, a really top quality oil.
The RBF is a very good brake fluid, one of the best, quite expensive though, so have a look at the Gulf RF800 if you want to save a bit.
http://www.opieoils.co.uk/p-69355-gulf-competition-rf800-racing-brake-fluid.aspx
Tim
oilman
Quote from: Jezza-7 on June 23, 2013, 05:36:50 PM
Tim,
Do you know what the recommended oil spec is? I don't have it listed.
Tim
It usually runs on just the standard oil spec but cause the pump is designed to pump fuel it needs to be a runny oil.
oilman
Hi
Sorry for the delay with this, I've been having a look around to see what I can see on the specs for the oil.
Based on what I can see, a really good fork oil will be ideal
http://www.opieoils.co.uk/p-852-silkolene-05-synthetic-racing-fork-suspension-fluid.aspx
A few people have used that in similar chargers in the past. Not cheap but very high quality.
Tim
Tim,
Would running redline 10wt oil be ok? Im assuming its very runny.
oilman
Hi
I don't know is the honest answer. When we asked a couple of oil companies before, the fork oil I mentioned above was the only one that came back recommended. The oil tech that analysed the original fluid said it was pretty weird stuff due to the way it behaved, so the only thing I'd suggest other than the original fluid is the Silkolene 05 fork oil.
Tim
