Author Topic: Standard Injectors/250cc chip  (Read 2840 times)
Re: Standard Injectors/250cc chip
« Reply #15 on: April 15, 2013, 09:10:42 am »
what injectors have you got it?  It should run Ok on the standard chip with standard injectors.  I'd not expect it to run very well with 250cc injectors and a chip designed for 180cc ones, it'll over fuel quite a lot.  Might run (badly) but it'll never have a chance of getting through the emissions test.
Offline Andy
« Reply #16 on: April 15, 2013, 09:34:31 am »
I'd re-book the MOT, or try to get it running on stock injectors and stock chip. If you go down the latter route, slacken the actuator off so you won't go on boost at all.
Offline AdzCM
« Reply #17 on: April 15, 2013, 07:36:07 pm »
Got it to run on standard chip and injectors. Then got my G60's today and fitted them with the other chip. Runs fine :)
Thanks for the help...
