Author Topic: G40 Version 2  (Read 47493 times)
Offline sleag40
  • Poloist
Re: G40 Version 2
« Reply #75 on: July 17, 2015, 09:17:17 am »
Been out and about in this a fair bit so far, even managed to spend a day at the Polo Social at Billing.
Hopefully more shows will be attended before the year is out.
« Last Edit: November 27, 2017, 08:08:17 pm by sleag40 »
Offline sleag40
  • Poloist
Re: G40 Version 2
« Reply #76 on: August 10, 2015, 11:09:36 pm »
It would appear that I've been driving this around with the king lead hanging off the coil! This is the state of the lead -
The terminal on the coil is similarly frazzed, somehow it still ran perfectly though?
I only noticed the disconnected lead when checking the oil!
New coil off eBay, and a spare king lead fitted, and its all in order again.
« Last Edit: November 27, 2017, 08:16:43 pm by sleag40 »
Offline sleag40
  • Poloist
Re: G40 Version 2
« Reply #77 on: September 10, 2015, 09:00:57 pm »
Thanks for the repair came in the form of a puddle of gearbox oil on the garage floor. What was left in there was drained, then the knackered selector shaft seal was replaced - it was all going well until the time came to refill the gearbox. The fill/level plug would not come out! I must have overtightened it in the past, as it was FT and ended up rounded. As there was no oil in the box, I couldn't drive it to my unit and get it on a ramp, so desperation set in. The only other means of getting oil in there is through the speedo drive hole, so the speedo drive came out leaving me with a tiny hole to fill it through. A piece of plastic fuel pipe and a little funnel were used for delivery - 3 litres needed to go in, and each litre took 40 minutes to unload through the skinny pipe. Arse cake! It's done now anyway, check out the comedy rig cobbled together to avoid holding the funnel while the oil trickled in!
Normal service now resumed.
« Last Edit: November 27, 2017, 08:21:28 pm by sleag40 »
Offline sleag40
  • Poloist
Re: G40 Version 2
« Reply #78 on: October 09, 2015, 08:40:07 pm »
Took this for a spin today, no oil on the garage floor this time  ;D
It's filthy, and covered in dead flies, but when the light levels are low you'd never know!
« Last Edit: November 27, 2017, 07:48:01 pm by sleag40 »
Offline sleag40
  • Poloist
Re: G40 Version 2
« Reply #79 on: January 30, 2016, 02:29:09 pm »
Finally got round to replacing the rounded gearbox level plug today, the ride out afterwards put a grin on my grille, which was very welcome after a few days of illness.
« Last Edit: November 27, 2017, 07:46:17 pm by sleag40 »
Offline sleag40
  • Poloist
Re: G40 Version 2
« Reply #80 on: May 03, 2016, 07:09:25 pm »
Thats a lot of ones.
« Last Edit: November 27, 2017, 07:44:33 pm by sleag40 »
Offline sleag40
  • Poloist
Re: G40 Version 2
« Reply #81 on: June 13, 2016, 09:51:27 pm »
Not been out in this as much as I'd like - thanks to another build. Gave it a miss today so I could spend a bit of time in it.
« Last Edit: November 27, 2017, 07:41:58 pm by sleag40 »
Offline sleag40
  • Poloist
Re: G40 Version 2
« Reply #82 on: September 24, 2016, 04:06:03 pm »
After 16k miles, the crappy jubilee clips I'd used on my charger to intercooler pipe finally gave up. I'd intended to change them a long time ago, but never got round to it - in all fairness, they did quite well!
Made a bit of room in the unit
The burst jubilee clip causing 100% boost leak
The cure, thanks to eBay
Normal service resumed again, thankfully! This car really is pointless without forced induction!
« Last Edit: November 27, 2017, 07:37:57 pm by sleag40 »
Offline physicsfool
Re: G40 Version 2
« Reply #83 on: September 25, 2016, 08:41:31 pm »
Looking good, went for a blast in mine after nearly a year, amazing how time flies. Cracking little motor
Offline sleag40
  • Poloist
Re: G40 Version 2
« Reply #84 on: December 27, 2016, 12:38:01 pm »
Cheers Martin!
Had a ride out in this yesterday thanks to a nice dry day.
Whenever I think about selling it, a good blast invariably changes my mind. :)
« Last Edit: November 27, 2017, 07:34:34 pm by sleag40 »
Offline sleag40
  • Poloist
Re: G40 Version 2
« Reply #85 on: May 27, 2017, 07:52:25 pm »
Finally got round to doing the cambelt on this today. Embarrassingly​ it's not been done since the engine was built in late 2007!
It's a hell of a lot easier to do when the engine is on a stand - the job was more of a faff than it should have been due to the toothed belt lower pulley being wider than a standard one. It's done now anyway, just needs a quick buff up and it's ready to enjoy again!
« Last Edit: November 27, 2017, 07:32:09 pm by sleag40 »
Offline sleag40
  • Poloist
Re: G40 Version 2
« Reply #86 on: June 22, 2017, 10:30:09 pm »
Just had these powdered, same size and offset as the RAs that are on there.
Came up pretty well considering their age
I don't know if they'll suit it or not - I guess I'll have to try them out at some point. :)
« Last Edit: November 27, 2017, 07:29:26 pm by sleag40 »
Offline randombadger69
Re: G40 Version 2
« Reply #87 on: June 24, 2017, 09:26:57 am »
Great looking G!  8)
Must get working on my original G.
Offline sleag40
  • Poloist
Re: G40 Version 2
« Reply #88 on: February 19, 2020, 07:03:27 pm »
Great looking G!  8)
Thank you kindly! It still scrubs up reasonably well even after nearly 8 years.  8)
MOT'd this today - first time its been driven on wet roads in my ownership! Hadn't even done 800 miles since the last test, I really need to get out in it more.  :(
Offline sleag40
  • Poloist
Re: G40 Version 2
« Reply #89 on: June 20, 2020, 03:24:44 pm »
The clutch pedal on this has been requiring more and more effort of late, and today it started to get noisy too. After changing the oil and filter, I changed the clutch cable too - no jacking or lifting required, just a little entry level contortionism and in it went. The difference is incredible - I probably should have done it last year!
Time to put some miles on it.  8)
