Author Topic: gear box oil check  (Read 1897 times)
Offline james22sniper
gear box oil check
« on: February 15, 2013, 09:52:45 pm »
Anyone got a picture of where the gearbox drain and fill plugs are? Thanks all
Offline Jezza-7
Re: gear box oil check
« Reply #1 on: February 16, 2013, 04:58:54 pm »
Have you read the haynes manual?
« Reply #2 on: February 18, 2013, 09:52:37 am »
don't have a picture but they are both on the side of the diff casing where the nearside drive shaft comes out.  There's two plugs screwed in with 17mm hex key fittings.  It's fairly obvious if you poke your head down there and have a look.
« Reply #3 on: February 18, 2013, 02:20:38 pm »
Thanks... I thought they were the ones but always good to have confirmation.  :)
