Bit of an update on the old project 180!
As most you will know i killed the engine a couple of weeks ago due to a dodgy valve and valve seat combo.
instead of sorting out the problem in the car i decided to take the whole lot out and do a proper job with seals, gaskets etc, currently costing ALOT of wedge!
Spent another fortune at VW and eurocarparts getting new seals and gaskets etc. Got a new clutch from a place in Yorkshire which is going on seeing as the engine and gearbox is out.
Got hayes old head which i have cleaned and lapped the valves in and also put new stem seals in, got a new wtaer pump which is actually the correct one this time and cambelt.
Got a metal headgasket this time so it will give a higher compression ratio which should help towards hitting that 180bhp.
The engine is currently on an engine stand, did a few odds and ends but can't really do much more as i am expecting a new camshaft next week so the head will go on when that comes (the dreaded headbolt tightening process) and new tappets will also be fitted too.
So the plan is get the whole engine back to one piece next weekend and hopefully into the car ready for the weekend after for the clubpolo RR day but its going to be tight!
Here are some pics anyway.
Parts waiting to be mated to the engine
Couple of pics for Dan of the new clutch.
