Intercoolers? wat you got
Started by djtez, November 21, 2008, 08:51:41 PM
djtez
please please 'g-spot' keep me dated with this...
maby a few foto's and tell me how you get on...
i mightbe tempted to move the standard ic, but the pipework that does the pain in the butt
G-spot
Quote from: djtez on November 25, 2008, 08:57:21 PM
Once the work starts I'll take plenty of pics, no worries...... :)
Robin
This is what i am currently up to.............
djtez
wow aesome
wat pipework you doing
how you runnin pipes from charger to this and this to the throttle body?
could anyone suply hoses for this ?
breadman
Quote from: Robin on December 01, 2008, 05:28:01 PM
What intercooler is that you're using Robin?
Jake
I'm wanting to get a front mount sorted for mine. Anyone who has one fitted, is there any chance you could have a quick look with a tape measure and give me some rough sizes so I can go for a look in the scrap yards? Also the end tanks would be easiest with rear entry from the engine side rather than the 2 sides I'd imagine? Where have people mounted theirs to?
breadman
Jake, the Cosworth Sierra ones are pretty good if you're on a budget.
They have cast alluminium end tanks with rearward facing 63mm inlet/outlet pipes. I have a 4x4 Sierra Cosworth one and the core size is 450mm long x 115mm high x 115mm deep. The overall length is approx 600mm.
The normal 2wd Sierra Cosworth ones are virtually the same but with 100mm (IIRC?) high/deep core.
My 4x4 one is for sale if you're interested?
djtez
breadman
#23
I'd like £35 plus postage.
djtez
kk would this still fit the same like 2wd version
i dont get the lingo on the (iirc) part ?
is it only 100mm high and 100 deep?
vwmk3jon
iirc = if i remember correctly.
i should be having a AW tracksport one fitted to mine shortly. Will get some pics when its been done.
breadman
Quote from: djtez on January 15, 2009, 09:34:32 PM
Yeah Terry, the 2wd ones are 100mm high and 100mm deep.
this is a 2wd cossie one with different end tanks made up so the pipes come off straight.  The normal connections on the 2wd one come off at funny angles, kind of 45deg on one side and different on the other.
sohailG40
mine looks just like that one is that a serria cosworth intercooler
Quotethis is a 2wd cossie one with different end tanks made up so the pipes come off straight.  The normal connections on the 2wd one come off at funny angles, kind of 45deg on one side and different on the other.
