boost return mod scrapped
Started by tdh-syorks, November 21, 2008, 06:53:55 PM
well kindof. lots of people remove charcoal canister when doing this mod.. it may have been that all the little breather hoses may not have been blocked up successfully
tdh-syorks
dunno pete i did a proper job of making sure everything was properly sealed and blocked up, the cars running much sweeter now its back to VAG spec, like i said at first i could have just been imagining the power loss, so putting it back is just piece of mind for me.
G-spot
Quote from: g40_jez on November 25, 2008, 09:18:24 PM
It occurs to me that you guys could be talking on cross purposes, if Hayesey means perhaps that the boost return valve is leaking or not closing properly - that would certainly cause a loss of boost.
I think cross purposes was the cause of this missunderstanding, think you guy's were reffrerring to the actual valve while I was harping on about the pipe/tube returning the un-used air!!  :-[
Oops sorry guys.
