you're wasting your time trying to do it by ear Dan, you need to get it on a gas analyser to monitor the CO levels, seriously, there's no way of properly DIY'ing it. But 550-ish ohms usually works. Setting it to that shouldn't be causing any problems.
yes but adjusting it to various different readings should give some indication of improvements which it didnt..the idea was to see if it would improve and then get it on an analyzer and then set it up exactly..i dont have access to an analyser right at this very moment...
anyway it made no difference whatsoever what ever setting i put it at really..not noticably so i set it back to 600 Ohms or 550 i cant remember now but around the level it was originally.
its defo not got anything to do with the co pot..
i tried it low around 200, 250, 400, 500, 600, 700, 800, 850, 900, 1000, 1050, 1100, 1150 and so on upto around 1800. you would expect some change at some point if it was this sensor...it didnt and neither did dk's as far as i know which was set up with an analyser.
