CO pot & Gearbox engine mount bracket (Side)
Started by Etches, October 13, 2012, 06:20:31 PM
Etches
Mines not functioning as its reading no resistance at all. Need one ASAP really as my wideband is showing a very lean idle. I'm at gti fest tomorrow if anyone is going and has one spare
Etches
cheys03
No resistance whatsoever between any of the 3 pins?
If it's just the adjustable bit (pins 1&3?) that's bust, then you could wire in a 1K POT from RS/Maplins and adjust to suit. Shouldn't need more than 1k unless the map is quite far out.
If it's the thermistor pins too though then this won't much use of course
Etches
Right I still need another CO pot to give back to the Mrs and she also needs a GB engine mount bracket for the pass side .
Hers has what looks like a MK1 golf conversion bracket made up so if anyone wants any pics of that it would be good
Very slim chance but i might have a gear box mount.
Will have a butchers.
Etches
Etches
Did you manage to have a look pal?
Etches
Yeah had a look but i cant find it anywhere, im sure i got one. Will have another good look today. Might be in the car as its away for winter.
Freddy77
Jez I believe your spare gear box mount is in the
Front of my g40 in the garage. I found one in there and wast sure if
It was mine or yours, I will check on the weekend,
Ah right lol.
Tom if its at freds i will let you know.
James
Etches
Etches
