Urgent help needed G40 build
Started by krazy*k, August 26, 2012, 04:34:10 PM
krazy*k
Putting my G40 engine in this weekend and we have found a part that we are not to sure where it goes
This is the part in question !!
Also what is the vacum that comes out the back of the ECU and where does it go ? Pics would be helpful
Cheers Kerry x
NeilG40
It connects to the charcoal cannister.
krazy*k
Thanks any idea with the ECU bit ?
krazy*k
Right got another one for you which way round do these go ?
Weeman
Yellow goes to the sensor closest to the cam pulley. Blues goes on the one next to it.
The vac to the ecu comes off the one way valve to the brake servo.
Hope that helps :)
The ECU one looks like this if you can see?
Coming from the bulkhead and going under the main wiring loom to the inlet manifold brake servo/vacuum feed.
And if you can see this pic this is where the 1st part you asked about goes.
The top of the saucer goes to the throttle body, the bottom connects to the t-piece line coming from the breather pipe and the one on the side of it goes the the s shape pipe that goes from the ISV to the back on the inlet manifold.
Hope this helps.
krazy*k
krazy*k
i have another one for you what end goes on the supercharger ?
samg40
