Help with Full Carpet and the rubber of antenna Polo g40
Started by G40BLUE, August 01, 2012, 08:13:36 AM
can be fitted over the top if you heat up in boiling water
Jacque
thnx for the tip, i will keep that in mind, although i m a bit scared if it would fail, i have nothing left :)
mstar
A Dutch website for custom fit carpets, ordered a set my self there and they made the boot carpet as well. Had to send in a template.
http://www.automatten.nl/
ereeiz
Hello, sorry yes. The door handle mechanism is the same on a mk1, mk2 Golf, mk1 Caddy, Mk1, 2, 3 Polo, Mk1,2 Jetta. the grommet/ gasket you need will fit from that kit.
If you want "Delocked" handles (handles with no locks in them) then look for rear door handles, again they're exactly the same minus the keyhole, etc and fit straight in. You will need central locking/ another entry method though of course :D
POLOMON
This is not entirely true if using golf handles ereeiz.
I followed this guide as posted by Alex:
http://www.clubpolo.co.uk/forum/index.php?showtopic=275936&st=0
