Author Topic: Broken gear box  (Read 4819 times)
Offline james22sniper
Re: Broken gear box
« Reply #15 on: May 09, 2012, 10:12:46 am »
Photo showing 8P and 085 box markings. So am I correct in thinking this is a basic Polo box and NOT a G40?
Re: Broken gear box
« Reply #16 on: May 09, 2012, 10:13:05 am »
fair enough, I'd have to agree with them then.  If you need to start buying new gears then it's VERY expensive.  Looks like your final drive set is knackered too.
Having seen that I'd say finding a 2nd hand complete box is the best answer too.
What code is on the casing?
Re: Broken gear box
« Reply #17 on: May 09, 2012, 10:16:18 am »
ah just seen your new pics.  Yes 8P is just a normal 1.3 litre 5-speed polo gearbox.  Not worth much at all.  You can find these for sale for not a lot.  They are the usual box to put on a g40 if the original ATV coded box is shat itself and you can't find a proper replacement.  The ratios are similar but not quite the same, about as close as you'll get.  Top end is a bit compromised and I'm not sure it'll do 60 in 2nd with an 8P (which it will do with an ATV).
Also, you can't fit an LSD to an 8P as they don't have bolt-on crownwheels on the diff.
But you've been using an 8P anyway so using another one shouldn't be a problem, it'll just be the same.
Re: Broken gear box
« Reply #18 on: May 09, 2012, 10:19:44 am »
Thanks for all your advice and help!!! I'm learning all the time! Its actually my sons car so he will be relieved that we should at least be able to get it back on the road! But I think I might advise him... no more trips to SANTA POD!!!  :)
Offline djtez
  • aaAAHH CHOOO!
    • its ma bebo site
Re: Broken gear box
« Reply #19 on: May 09, 2012, 10:35:48 am »
now now , cant be harsh on the boy..
thats what these cars are for .. fun ;D
Re: Broken gear box
« Reply #20 on: May 09, 2012, 01:30:46 pm »
hayesey... what can you tell me about an AHD box? I have been told this is a direct replacement for the original having given the reg no. to a reconditioning company. Thanks.
Re: Broken gear box
« Reply #21 on: May 09, 2012, 01:36:04 pm »
I think that's a GT gearbox, not the same at all. Much shorter ratios.  An 8P would be better.  I see someone has replied to your wanted thread with a proper G40 box for £200, I'd buy that if I were you.
Re: Broken gear box
« Reply #22 on: May 09, 2012, 01:42:24 pm »
So the G40 box and the 8P have the same fitting dimensions and should go straight on?
Offline djtez
  • aaAAHH CHOOO!
    • its ma bebo site
Re: Broken gear box
« Reply #23 on: May 09, 2012, 02:01:46 pm »
yes
Re: Broken gear box
« Reply #24 on: May 09, 2012, 02:06:08 pm »
I feel a trip to the north coming on then!  :)
Re: Broken gear box
« Reply #25 on: May 09, 2012, 02:38:30 pm »
they are the same externally, just different gear ratios.
Offline Nick_S
  • 189.6 bhp @ 8psi boost
Re: Broken gear box
« Reply #26 on: May 09, 2012, 07:40:58 pm »
Ouch, looks like the end bearing on that relay shaft has fell to bits (nothing left there now) causing damage to the final drive set and gear set next to it!
Deffo not worth repairing.
« Last Edit: May 09, 2012, 07:42:32 pm by Nick_S »
Re: Broken gear box
« Reply #27 on: May 09, 2012, 07:59:22 pm »
 :(That about sums it up! Things were looking up earlier when I had a good response to my wanted add but the guy disappointingly put his price up when I expressed an interest. Maybe it would be worth it but to quote one price and then stick another fifty quid on top is not very friendly! Disappointing!
Offline Nick_S
Re: Broken gear box
« Reply #28 on: May 09, 2012, 08:06:07 pm »
Just buy a second hand 8P or CEG gearbox. It really isn't worth paying the premium for a G40 box unless your planning on fitting an LSD?
Re: Broken gear box
« Reply #29 on: May 09, 2012, 08:24:23 pm »
 :)Thanks.. My search will go on!
