Vauxhall 256mm brake setup
Started by Andy, March 27, 2012, 12:26:58 PM
Andy
Pair of Vauxhall calipers and carriers to convert your 86C Polo to 256mm brakes. These come with the correct grade (expensive...) shoulder bolts required to bolt the carriers to the strut. No discs, but come with some used pads if you really need 'em!
Now £50!
Based in South Warwickshire, can post if required.
djtez
Hi Andy, kinda tempted with this over tsr brakes
1 the price
2 ready available discs ...
Can you verify the thickness of disc
Also any recommendation on pad disc combo?
Andy
256mm setup (calipers, carriers and shoulder bolts) is £125.
Discs to use are the Mk2 Golf ones, and the pads should be the Vauxhall ones - very readily available! I'd use standard vented discs and some good pads (Ferodo DS2500 are popular) with them.
Andy
Edited as the shoulder bolts I've got are the wrong ones, so price has been ammended accordingly!
Used pads are included.
Andy
djtez
£70 delivered?
Pay pal you ?...
Andy
Postage will be about £15, so that's a bit too cheap for me.
djtez
What kinda deal can you do for me posted then buddy?..
Andy
Still have these.
Now £50 plus postage.
parlog40
Hey have you still got this brake set up
Andy
