Another Advise on polo G60 people ...
Started by djtez, March 23, 2012, 05:41:25 PM
djtez
Is 28 teeth 78mm? Standard pulley?
I'm goin for the 30lbs mustang ones it looks like.
PR23M3K
28 teeth = 75 mm
I'm going to change injectors to Volvo's 0-280-150-785 using 24 teeth pulley.
djtez
And by 24 teeth 68-70mm
The 70mm I looked at is 70mm
I've not yet found a 68mm toothed pulley
PR23M3K
German gears have 8 mm pitch, so for example the outside diameter of 26 teeth gear
Do = 8/3,14 * (26+2) = 71,3 [mm]
Precise diameters for each pulley:
28 teeth = 76,4 mm
26 teeth = 71,3 mm
24 teeth = 66,2 mm
22 teeth = 61,1 mm
djtez
That's interesting stuff thanks for posting..!
On the max rpm website they offer a 70mm which they call 24 teeth too and on another site bar tek I think? It's 68mm?...
It's 24 teeth I'll run.. Seems a popular choice and a am looking for max power
Was it that charger on ebay for £750?
When i looked at a jabba stage 4 it was ported really well. Its the same as a full blend. When i had a PSD full blend and a R1 jabba charger, the jabba one was miles better than the full blend. Stage 4 on a g60 is the same as an R1 spec g40.
Oh and its defo worth a rebuild! Wouldnt trust g werks! You will need the high rpm bearings too!
djtez
Yes thanks jezza..
No the Charger was on my other site Scottishvag.net
i bought it of a friend actually £380! Was up for 500 so i feel a grabbed a wee bargain!
So im assuming you will run a Stage 4 too ?
No wanting to be running a lesser Spec! ..
now am looking for injectors i can only find a volvo/saab set 350cc 32LB i dono if they will work.. but im assuming yes as they listen jetta 2.0
djtez
Quote from: PR23M3K on March 25, 2012, 09:23:51 PM
28 teeth = 76,4 mm
26 teeth = 71,3 mm
24 teeth = 66,2 mm
22 teeth = 61,1 mm
a found this Price: € 359,-
G60 (N=6000 r.p.m.)
Tooth Belt Drive (mm)   Teeth   r.p.m.
78 mm   approx. 32   10.500
74 mm   approx. 30   11.200
72 mm   approx. 30   11.200
70 mm   approx. 28   12.000
68 mm   approx. 28   12.000
65 mm   approx. 26   12.923
63 mm   approx. 26   12.923
60 mm   approx. 24   14.000
this was on RPM tuning website..
Well im not sure if im gonna use jabba as im gonna get it serviced by someone else and get his mate to do the porting asi have seen pics of his work and its better than jabba!
You need to get the high rpm bearings though.
djtez
I've mailed a few people and also jabba.
Once a pick up charger I'll inspect to see if the porting is enough.
Where did you buy all your parts ie map sensor conv bracket belt pulley
I was lookin to get the lot off max rpm
djtez
Right now im looking at spark plugs..
W5 or W4? .. do i need the colder plugs?
