No Gears
Started by james22sniper, March 12, 2012, 10:01:24 AM
james22sniper
Morning all...
My son reports having no first second or third gear having limped home in top last night. Gear stick is wobbly. Any thoughts before we have even had a chance to look under the bonnet later?
Thanks!
check out the gear linkage first.  It may be loose or broken, it's underneath the car, just have a look at it and see if it looks OK.
james22sniper
Had the car in the air last night... the gear shift linkages had seperated! Because....... the rear lower engine mount between the gearbox and car body had snapped!!! The gearbox dropped and tilted enough for the linkages to just seperate. Whipped the mount off... cleaned it up... welded it back together... refitted it and reconnected the gear shift linkages and all go again!!!   :)
which part of it had snapped?  Any pictures?
james22sniper
I have pics of the mount, off the car, that had snapped... or my son has on his phone. Will get them and attempt to attach them here.
james22sniper
http://www.polog40.co.uk/forum/index.php?topic=6869.0
In this link... 2nd picture shows the equivalent of the component that had snapped.
I just meant pics of the actual snapped one, I was interested in how it has failed.
james22sniper
Will post pics of the actual snapped one when my son sends them from his phone. :)
oh so it's not a standard mount.  Looks like a PPS one.  Obviously not the best welding again.
yeah looks like a PPS one but is slightly different to the way it mount on the chassis. But if you can remember this is what happened to my mount from PPS, except it didnt crack as bad.
Justin14100
Quote from: Jezza-7 on March 14, 2012, 09:31:09 PM
I have that mount laying around somewhere Jezz, I think it cracked in the same place though.
grungeisdead
I've yet to have one crack yet, Adam's had a PPP one snap on him, but has rewelded and its been fine since.
Was he the fella who drove over a pot hole?
grungeisdead
dont think so jezebel, mind you i tend to tune out when pidgeon starts talking to me and all i hear is 'cooo cooo cooo'
