Author Topic: Lowering Poly Camber Adjustable Front Top mounts -10mm and Rear top mounts  (Read 5079 times)
Offline Phil
These are now in stock, will lower your car 10mm and are made from polyurethane. They are camber/castor adjustable via the offset bearing. Made in a .75 shore rating so not too stiff for road use. Excellent solution to the irritating early polo top mount.
£75 delivered.
Poly rear top mount set - £25
Will do a discount on any combination of parts.
EG. £20 off Rear axle set with front and rear top mounts.
Offline randombadger69
Re: Lowering Poly Camber Adjustable Front Top mounts -10mm and Rear top mounts
« Reply #1 on: November 15, 2011, 06:24:34 pm »
How are the front top mounts secured into position?
Offline ereeiz
« Reply #2 on: November 16, 2011, 02:37:25 am »
Do you get a discount if you buy fronts and rears together then? If so, how much?
Anyone used these yet? How do they compare to standard ones and any other versions available? (I'm on the lookout for top mounts but would rather go for uprated ones as opposed to std versions)
Offline Etches
  • Still got the G...
« Reply #3 on: November 16, 2011, 06:04:54 pm »
Im in the same boat also, after getting some coils off phil, ive been waiting around for these
Offline si polo coupe
Are these still around phil
