Passed MOT, But revs need revising.
Started by gavin.starr, October 04, 2011, 08:06:37 AM
gavin.starr
Might have to give that a try then as its still doing it. I have tweaked and tweaked but to no avail.
Robin
ah good news you got it running, you found 5th gear?
have you checked for any air leaks?
gavin.starr
Yea ive found 5th, but its slowly disappeared again i have to slap the stick across to get it into 5th now so i think its settled and just needs tweeking again.
Ive not had chance to check for leaks or anything yet as im in the mist of packing due to moving house, and getting my supra looked at as the big end bearing have failed, so not a happy bunny at the moment.
I will report back when ive done it.
What i was going to do was get an empty tin of beans and attach a bike tyre valve and a gauge to it, attach it to one end ie the intake pipe to the charger, and blank off the end of the pipes it ends up at the throttle body and see if i get any pressure drop across the range. If so i will then start to try and find a leak if any.
