Stage 3 Subframes - pps vs ppp
Started by prankstar2003, August 03, 2011, 10:32:42 AM
prankstar2003
What's the difference between the two then? I know lots of folk on here are associated with ppp in some way, but please keep the replies as neutral as you can. As fa as I'm aware, the ppp item is considered better but why? I'm looking at getting one from either supplier, but it won't be for track use if that makes a difference
Also, what are replacement parts like to source as they are all bespoke arent they? Also, tca polybushes are ok to use with then right?
prankstar2003
Where's the write up chief? Which one did you go for?
I started off with a pps one as i was low on budget plus i wanted to see what the difference were. So after a year or so of driving i swapped over to the ppp one once i had some money aside for it.
