Vacuum supply
Started by dub-disaster, July 24, 2011, 10:31:00 PM
dub-disaster
I need a vacuum source for my BOV, 6 psi boost switch and my boost gauge. I have drilled and tapped the manifold to accept air line fittings is it ok to supply all of those things of the same vacuum supply? Wasn't sure if the BOV would interfere with the boost gauge or 6 psi boost switch ??
no I've got mine all off the same take off.  The boost switch doesn;'t have to be all that accurate anyway and a gauge doesn't matter.
