Author Topic: Engine Temperature  (Read 6812 times)
Offline rocore
Re: Engine Temperature
« Reply #15 on: November 12, 2008, 07:54:52 pm »
Just fired some current in the fan.. that seems to be working fine so think the new switch that was put in last week is a dud... or there is a dodgy wire somewhere!
« Reply #16 on: November 12, 2008, 08:05:09 pm »
either new switch is a dud - or often under the switch in the radiator is full of crud
Offline rocore
« Reply #17 on: November 12, 2008, 08:34:10 pm »
Will strip it out at the weekend and check it out...
Offline rocore
« Reply #18 on: November 15, 2008, 06:00:04 pm »
I checked it all out today...
The switch it coming on at the right rad temp... but whilst the rad is only reaching 90 degrees for the fan to cut in... the temp gauge is reading 110 as that reading is taken from the Stat housing. that right? then the fan kicks in on speed one and the temp gauge goes back down to around 90...
I have gone and bought a 3 way switch to mount on the dash so i can turn the fan on manually if i want. Also... can you get stats that open at lower temps? and would it be worth changing the black temp sensor on the stat housing.... incase its giving weird readings?
hope that all makes sense!
Offline rocore
« Reply #19 on: November 17, 2008, 01:32:31 pm »
Car doesn't go over 90 degrees my new switch turned on... woop.
Offline lance
« Reply #20 on: November 19, 2008, 06:15:03 pm »
i have bought 2 8" slimline fans gonna put one on the front an one on the back wire them up so one is on at first speed an second comes on with speed 2. well ill see if i can get to do that ha ha.
Offline rocore
« Reply #21 on: November 23, 2008, 07:55:00 pm »
let me know how that goes...  think i have got a rado fan now... will bung it in when i have a spare 5 mins!
