New Fuel Pumps?
Max:
Im after getting some new fuel pumps as im still running the ones off my old GT engine which is a bit of a ticking time bomb.
Would VAG ones be suitable or is there a need for uprated ones maybe? (G40Turbo)
hayesey:
I don't think you need to worry about higher rate fuel pumps till you get above 200bhp. Best place for the standard Bosch pump is GSF. Still about £90 though. Ask yoof what pump he uses, it's a higher rate one and if I remember correctly it was cheaper than the standard one (but I might have imagined that bit!)
Max:
Ah thats ok then, standard one will be fine.
I might aswell get the in tank pump at the same time so its all fresh.
hayesey:
yeah they're only cheap so worth doing.
vwmk3jon:
my local vw quoted me £172.80 for the inline pump..........i'm off to gsf.
Navigation
[0] Message Index
[#] Next page
Go to full version
