Author Topic: Compression test results  (Read 2377 times)
Offline xrrich
« on: May 23, 2011, 07:02:08 pm »
Got chance to get my hands on a compression tester, I had suspicions that head gasket was going, its leaking oil and water, and looks like there is oil in the water.
Results
Cylinder1- 145psi
Cylinder2- 150psi
Cylinder3- 155psi
Cylinder4- 155psi
I don't really know where to go from here, any help would be great
Rich
Re: Compression test results
« Reply #1 on: May 23, 2011, 07:41:02 pm »
Rich,
Those pressures look strong, what colour are the plugs?
Could of course be fluid in the combustion chamber upping your CR  ;)
Offline xrrich
« Reply #2 on: May 23, 2011, 10:20:51 pm »
Ah nice to hear, what is average pressures then?
The plugs were all dry slightly blacky,brown, they look normal.
Fluid in the combustion chamber upping my CR?
Rich
Offline djtez
  • aaAAHH CHOOO!
    • its ma bebo site
« Reply #3 on: May 27, 2011, 10:26:52 am »
water or oil in the cylinder can seal up small gap's in the piston rings giving it a seal allowing it to up the compression.
i think (only thinking) 10 bar is quick good.
between 8/10 bar i think is acceptable..
but thats just memo from haynes..
Offline Etches
  • Still got the G...
« Reply #4 on: September 01, 2014, 07:38:48 pm »
Just to bump this thread up, I've ended up with a poorly G this weekend after winding the boost up. Boost was set to 21psi but it suffered a creep at top revs and something went pop and she overheated in a matter of seconds. My compression test results were as follows;
149  163   168   160
Wossner Pistons with 6n HG
« Last Edit: September 01, 2014, 09:00:04 pm by Etches »
« Reply #5 on: September 01, 2014, 08:06:28 pm »
Pics of plugs  :)
Offline z3i
« Reply #6 on: September 01, 2014, 08:59:24 pm »
Just for the record incase people look at this thread for reference my results with acralite pistons 1341 BVH were
170/170/172/175
