Author Topic: Bigger bottom end....  (Read 10433 times)
Offline youngprodigys
  • G 3URO
Re: Bigger bottom end....
« Reply #15 on: February 16, 2011, 04:36:17 pm »
type "g40 stroked" into the search box. comes up with bore 77, comp height 34.45 (i think) pin 20.
Offline dani1326
« Reply #16 on: February 16, 2011, 06:31:09 pm »
The pistons are special order only, iv got to order 12 pistons to even get a price, what are my other options??
Offline Richg40
« Reply #17 on: February 16, 2011, 07:09:07 pm »
Either find some peeps who are willing to go in on a deal and buy a set or find one of the few sets that's out there and hand over some big bucks. There's gotta be 4 or 5 sets out there, with at least 1 or 2 sets that are sitting in someone's shed doin' sweet FA.
Offline dub-disaster
« Reply #18 on: February 16, 2011, 08:28:34 pm »
Dig deep in your pockets and get some quotes from other manufacturers like je for some one off pistons but as I highly doubt you know the exact spec unless somone who has a new set (young prodigys!) would like to let you measure them up and get a custom one of set made
     Either way it's going to be big bucks but if your building a new 1.5 g40 motor you better get used to big bucks my 1341 cost plenty and this will cost a bit more
Offline scotsjohn
« Reply #19 on: February 16, 2011, 09:05:01 pm »
I'm seeing 77mm Wossner pistons for £550 on ebay
« Reply #20 on: February 16, 2011, 09:10:41 pm »
you need to ensure they are stroker ones for 77mm though or you may get valve clearance issues etc
Offline dani1326
« Reply #21 on: February 16, 2011, 10:07:58 pm »
Yer that's why there special order or is it possible to skim a standard set??
  • G 3URO
« Reply #22 on: February 16, 2011, 10:40:20 pm »
thats what my plan was with my other engine! skim a standard set to the 34.45mm deck height.
i really need to work it out. if i dont flog my bottom end- i will CAD it up and work out what i need to do to the pistons in order to attain 8.0:1 comp ratio.
when i fo it will be a super cheap way of having a 1398 bottom end. i will measure up the 1W pistons aswell so i can see whats needed for a 77mm set
Offline polo classic
« Reply #23 on: February 17, 2011, 09:43:08 am »
I'll be ordering some custom JE 8,5.1 for my 1W soon
Offline scotsjohn
« Reply #24 on: February 17, 2011, 09:24:39 pm »
I haven't got the maths for it but could you downstroke the crank? There must be plenty of meat on the 1W compared to the standard G.
Offline Richg40
« Reply #25 on: February 17, 2011, 09:27:10 pm »
You what?
Offline scotsjohn
« Reply #26 on: February 17, 2011, 09:36:04 pm »
You can alter the stroke of a crank by re-sizing the journals.
Offline Richg40
« Reply #27 on: February 17, 2011, 09:49:50 pm »
Don't make me quote myself.
« Reply #28 on: February 17, 2011, 10:23:09 pm »
You really can't...
  • G 3URO
« Reply #29 on: February 17, 2011, 10:34:38 pm »
the difference in the pistons is in the height. they are like normal 77mm pistons yet are not as tall and have a wider bowl on them to deal with a higher compression ratio then on a stock G
