Driver side earth
Started by JregGT, February 12, 2011, 08:58:35 PM
JregGT
Evening Folks, I had a search on here, and found all the earthing points.
Either E1 or E2 the body strap on the drivers side, i'm a little unsure as where to bolt to engine wise.
Befor ethe engine conversion it went from body to alternatort bracket!!! But now with the charger there are obviously lots of moving parts. So I wondered where VW had it fixed.
I have thought about stripping a previously lugged end, and form a soldered ring to go under the 17mm engine bolt , or maybe onto one of the 13mm bolts.
Cheers in advance folks
Rich
goes from a 10mm on the charger mounting bracket to the chassis leg 13mm nut
JregGT
After reading an article I found by (i think hayasey) it confirmed onto the charger.
I was just a bit worried about it being a bit close to the belt etc. I have a day off tomorrow, so an going to have a good look, and a go at setting the CO pot up.
Ta Rich
it goes in a U shape towards the front of the car to avoid the belts - you'll find it'll probably run better wtih that earth on!
JregGT
I'll get on it tomorrow. I did run in a couple of fresh earths to various points when changing the loom, directly from the neg, but I definitely want to get that earth on. Cheers again Peter
Rich
