Author Topic: 1992 Polo G40 - Metallic Grey  (Read 17638 times)
Offline grungeisdead
« on: October 28, 2010, 02:43:23 am »
Genuine G40 Grey metallic, non sunroof.
K reg 173,000 miles on shell
Engine:
Block replaced at 150k with a PSD one rebuilt at 100K included, new oil pump, new rings, all bottom end shells, seals, gaskets etc.
Schrick Camshaft with vernier pulley.
Ported/flowed head, new valve and guides, gaskets, seals at engine rebuild.
Thinner metal headgasket,
GT manifold port matched to head,
51mm throttle body,
G60 green injectors,
Jabba induction kit and heatshield,
Boost return mod,
PSD 4 branch exhaust manifold and full PSD 2 box exhaust system(Fully heat wrapped) with receipts for around £700,
Helix Organic Clutch,
RPM Tuning Cast Alloy Sump (no longer make these),
Mocal Thermostatic Sandwich Plate with 16 row left front mounted oil cooler,
Stage 4 full blend charger,
65mm PSD Alloy Toothed Belts,
G-lader serviced June 2010, oil seals and apex seals with fresh klubber grease and new gates belt.
Custom mapped at PSD about 3 years ago with all upgrade parts fitted.
Water injection kit plumbed in and built in to activate at high boost. Not wired in at the minute.
New fuel tank fitted.
Suspension/Chassis:
PPP Subframe stage three with wishbone conversion
Uprated driveshaft with new CV joint.
Front Upper OMP Strut Brace.
Rear Upper OMP Strut Brace.
HnR Cup Kit - 60/40
New Rear Beam bushes(rear beam stripped, cleaned and painted late 2009).
Brakes:
256mm front discs with Audi calipers.
Rear shoes replaced 2009.
Goodrich stainless Braided Lines throughout.
Wheels:
14" BBS RA's with Falken ZE519
Interior:
White dials with custom blue back light and matching heater controls,
3 off matching white gauges '0-15psi boost pressure(with calibrated correction chart), oil pressure gauge, oil temperature gauge in radio DIN slot,
AFR gauge and battery meter built into button blank.
Alpine headunit in lower dash cubby with remote control.
Roof wrapped by DKnight in textured black vinyl
New gear gaitor
leather VW gearknob
fire extinguisher
Comments:
couldnt resist this little gem, as it completes my mk1-3 trio! i am one very happy bunny!
few tiny little bits to sort out, but these are all minor mk3 specific faults, the car runs flawlessy and i am throughly impressed, big respect to my man barney, and to jason (g-spot) for his hard work and dedication, which has made this G into quite the beast.
will take some current pics soon after a good polish =]
click me
the following will be up for sale - does anyone have any guesstimates as to pricing?
G40/GT exhaust manifold and de-cat downpipe + extra pipe tapped for lambda probe
unserviced original charger - 150k
1 full blend charger needing apex seals
BMW Front mount intercooler
RPM Tuning 68mm pulley + matched chip
also got the following healthy list of spares,
OE Charger pulleys + v-belts
G40 Alternator
G40 Engine Mount
G40 Starter Motor
G40 Pistons x 4
G40 Tappets
G40 Sump
G40/GT Passenger Rear Arch Trim
G40 Beru Lambda Probe
G40 Standard Intercooler VGC
G40 Standard Cam
G40 Charger Outlet Collar
G40 Knock Sensor x 2
G40 Various Boost Pipes
G40 Injector Rail + Loom
G40 Inlet Manifold
G40 Water Pipe Rear
G40 Charger Oil Feed Pipe - Old
G40 Charger Oil Feed Pipe - New
GT Injectors
GT Early Spec Rear LIghts
Mk3 Polo Drivers Headlight
Mk3 TCA - no rubbers
Mk3 Gearbox Mount Rear - No Rubber
Mk3 Coil - No Amp
Mk3 Rear Brake Shoes
Mk3 Heater Controls
Oil Catch Tank
Stub Axle Spacers x 6 (10mm)
Lucas 54 Calipers stripped for powdercoating + seals + pistons and bolts (no carriers)
another full blend charger needing apex seals
Offline karmann
Re: 1992 Polo G40 - Metallic Grey
« Reply #1 on: October 28, 2010, 04:02:46 pm »
Love this car dude, respect. :D
Offline Alex
  • Hack
« Reply #2 on: October 28, 2010, 05:30:05 pm »
Really good example this, nice one! ;D
Offline Turbodaily
« Reply #3 on: October 28, 2010, 09:15:40 pm »
Lovely car this, lets hope it settles in nicely with the other 2 and doesnt get jealous! lol
« Reply #4 on: October 29, 2010, 04:39:42 pm »
you mean the other three :lol: i'm sure they will play nice
Offline supercharged spaniel
  • GRRRRRRR
« Reply #5 on: October 31, 2010, 04:30:44 pm »
cheeky!  Love grey ones.  Enjoy it!
Offline Turbodaily
« Reply #6 on: November 01, 2010, 12:10:18 am »
What the hell is that orange thing by the brake fluid res?
« Reply #7 on: November 01, 2010, 01:11:07 am »
cheers georgia ;) i am enjoying it fully and it shall be looked after well =]
turbs - its a oil breather pod with guaze, will change it and point it downwards, but eventually get a catch tank so i dont get a dutty oily bay!
now sitting on a HnR Cup Kit!
Offline youngprodigys
  • G 3URO
« Reply #8 on: November 01, 2010, 07:31:15 pm »
looks well sweet mate!!!!
Offline vwmk3jon
« Reply #9 on: November 01, 2010, 09:41:27 pm »
And there was Saf telling me it was his dildo :lol:
I cant see you working on the other two now mate now that you've got this to play with ;-)
Offline Turbodaily
« Reply #10 on: November 01, 2010, 11:45:45 pm »
Cool man, looks muchos better.
Yeah surely this one will be sapping all of your spare time/monies sooner or later... nature of the beast! lol
« Reply #11 on: November 02, 2010, 09:44:07 am »
cheers dudes =]
naah theres not much that needs doing on this beast to be fair!
replace all engine mounts with new VAG rubbers
rewire up oil pressure and temperature guage
remove aquamist and sell
possibly fit FMIC but i dont think its required
sort dropping drivers hinge
give the car a full mop
steam clean the bay
fit a catch tank
clean up and paint some engine components
remove rear brake light
change quarterlights to bonded versions
change heater blower, or clean/oil fan to stop it squeaking!
black side indi's
remove G40 badges and put on Polo Coupe badge on rear
probably going to sell the PPP frame to a friend and a buy a PPS one, as I like new things.
then all it needs at some point is a bit of rust tidying up and a blowover!
As for the other cars, i've got a new engine coming for the peril, and the inlet manifolds for the carbs should be ready soon, but before i stick it in the peril, itll all be going in the mk1 polo and that'll get taken for an mot so i have a list of work that needs doing on it, before i take it to get sprayed up.
GT has sold now to a friend, and gets to stay local which im pleased about. Just need to move house and get somewhere with a garage and i will be the happiest pup in town woop woop
« Reply #12 on: November 02, 2010, 06:23:27 pm »
Bare in mind if you remove the Aquamist it'll need remapping to suit. That car's had a custom map from Steve with the 'mist turned on. Personally I'd leave the Aquamist on!
« Reply #13 on: November 02, 2010, 09:21:07 pm »
cheers dudes =]
steam clean the bay
fit a catch tank
black side indi's
Paint it?
« Reply #14 on: November 03, 2010, 12:57:05 am »
andy - the aquamist is plumbed, but not wired in. i need to do some reading up on the kits first, before i make a final decision really. didnt think the aquamist would have an effect or require the car to be mapped to suit. if you guys dont mind, id be happy to bring it over to you, i know the area round your unit well as my old unit was only a stones throw away. wouldnt mind someone with a keen G eye to cast it over the motor.
yoofenstein - not really the same is it painting it?! Its not for a colour change, its more for some nice new rose-joints and I have one before and rated it highly. I cant fault this one, however, but the cost of change wouldnt be much, and it would mean adam would get a cheap subframe for his own G.
only thing i want to sort it a clunk when changing gear, and going over rough surfaces, mainly originating on the left side of the car, the steering arms are all fine, TCA's are fine and the top-mounts are good, so im suspecting the minute, its the rear gearbox mount rubbers are a bit past it, so once they are replaced, hopefully the noises will be gone and if not thats another bit of troubleshooting out the way, and less parts to check.
out of interest - does anyone know if this cars ever seen the rollers in its current guise? and does 10 psi of boost sound like at higher revs? the car is really nice giving good off-boost power, and around 5psi of boost from 3-5 and 10 above, which means you can get some go, without spinning up the wheels.
