22mm master cylinder
Started by dub-disaster, October 01, 2010, 06:29:01 AM
dub-disaster
Doing my brake upgrade with 256mm set up and 22mm master cylinder, problem is I bought the master cylinder brand unused but from a bloke on club polo. But when looking at it next to my old one it looks identical evan down to the part numbers on the side are the same although they look to be different brands.
   Is there any thing obvious I can look for to confirm it's a 22mm one ??
stock ones have 3 outlets and 22.2mm have 4 outlets (one blanked off)
dub-disaster
dub-disaster
My old one had 4 outlets with one blanked of by a bolt does that mean it was probably a 22.2 mm job ? Do the standard ones only have 3 connections then and not just 4 connections with one blanked of ?
Quote from: dub-disaster on October 03, 2010, 08:17:50 AM
sounds like you havea 22.2 fitted yeah.  Stock ones only have 3
JregGT
For this conversion, is it simply a remove the 19mm and replace with the 22.2mm? Other than the blanking plug, nothing else?
Cheers Rich
dub-disaster
Yup looks like I've got a spare 22.2mm one aswell ;)
JregGT
Meant to ask also, use the original polo brake resevoir?
cheys03
Yup, original reservoir fits with a little 'gentle' push.
JregGT
