Poll
is it a common problem
0 (0%)
0 (0%)
Total Members Voted: 0
Author Topic: driveshaft cv joint loss of drive  (Read 1691 times)
Offline curtisg40
« on: September 30, 2010, 10:41:20 pm »
bought a gt/g40 few weeks ago and i snapped the cv joint last nite had it fixed today and i think its happened again is this common problem ?
Offline dub-disaster
Re: driveshaft cv joint loss of drive
« Reply #1 on: September 30, 2010, 11:33:04 pm »
Can happen on the higher powered ones when being used in anger hayesey snapped one recently but his car is around 200bhp with a 4 paddle clutch and he was launching it very hard on a drags strip. If it keeps happening maybe it's not been fitted correctly. Where is it snapping ?
« Reply #2 on: October 01, 2010, 09:34:47 am »
haha, launching it hard was a kind of way of putting it :) being stupid is more like it!
I don't think it's a common thing though.
What CV joints are you buying?
« Reply #3 on: October 01, 2010, 09:56:18 am »
Launching hard was my way of putting it politley  ;D
Offline curtisg40
« Reply #4 on: October 01, 2010, 03:48:19 pm »
put the g in the garage today and the mechanic said it could be the drivshaft not conecting with the gear box but it drives fine sometimes and then dosent drive at all, what should i do?
Offline cheys03
« Reply #5 on: October 01, 2010, 05:31:35 pm »
Sounds a little weird. Have you got any further details please of your symptoms - when it drives, when it doesn't, if there's any warning before the problem etc.
Have you taken it to the same garage that changed the CV joint?
Offline curtisg40
« Reply #6 on: October 01, 2010, 05:48:03 pm »
called the aa this mornin drove fine up and down my drive way took it out on the road for a quick spin and when i went to pull away it seemed like the driveshaft wasnt engaging just made just made a loud buzzing noise and there is no warning whatsoever
Offline youngprodigys
  • G 3URO
« Reply #7 on: October 01, 2010, 07:23:46 pm »
thats a proper job you did there hayesey!
Offline hardchargin40
  • Older, Wiser, Greyer.
    • The Roadster.net
« Reply #8 on: October 01, 2010, 11:44:34 pm »
What they change?  the whole driveshaft or CV joint?  2nd hand Driveshaft?  Can you identify if its inner or outer causing it?  I'd go with Inner.  Jack up both fronts, put on axle stands and spin you wheels underneath it, putting an applied force against joint to see if it breaks away.
Should just be a new shaft required if it wasn't new to start with or strip it and do it again.
