Author Topic: Lance's G40 turbo with ITB's  (Read 38064 times)
Offline lance
Re: Lance's G40 turbo with ITB's
« Reply #45 on: August 24, 2012, 09:32:29 pm »
got a new turbo
fitted it
now needs to go for a final mapping session and then bodyshop for a few bits sorted.
« Reply #46 on: August 24, 2012, 09:36:51 pm »
28RS?  :o
Offline lance
« Reply #47 on: August 28, 2012, 09:22:41 pm »
28r mate well gt2560r. runs really well now. very happy with it. any news on your turbo then? them gt2554r from turbo dynamics are not bad money. i was tempted but went with the .60 in the end.
out of interest what oil do you run in yours yoof?
am going to buy a petrol tank for mine soon. anyone know where is best to buy one?
« Reply #48 on: August 29, 2012, 04:55:54 pm »
Yup, I've just bought a new one from them, was tempted by the 2560R but I'm happy enough with the 2554R currently, already breaks enough drivetrain/engine components!
Oil is good quality 10W-40 Semi-Synth, change it every 3k or so as the filter is small and it gets to ~130'C on trackdays.
Offline jez1272gt
« Reply #49 on: August 29, 2012, 06:56:39 pm »
Jesus that 2560 looks ridiculous... which is a good thing!
Offline Nick_S
  • 189.6 bhp @ 8psi boost
« Reply #50 on: August 31, 2012, 02:47:05 pm »
WOW! only just updated myself with this thread. Nice one on achieving that power, good to know there is still progress to be made with fresh ventures in polo engines :) When i was first looking into 1.5's with turbos thats the sort of power I was looking towards, but hats off to get there with a 1.3 If I still had a mk3 then it would have a turbo'd 1.5 in there by now, but i'm sticking with mk2, so no room for turbo and huge intercooler :P
« Last Edit: August 31, 2012, 02:52:32 pm by Nick_S »
Offline dub-disaster
« Reply #51 on: September 01, 2012, 07:33:10 pm »
just looking back over your thread lance and one thing I've wondered is, where do you get a common vacuum source for things such as brake servo MAP sensor etc...etc.. i can see that yohve may be able to get a source just under one of the throttle plates but surely that's only the vacuum of one cylinder and would give poor signals/not enough vacuum to run ancillarys..Or have you removed these things and got around them by running un assisted brakes/supermarket management.
Offline lance
« Reply #52 on: September 03, 2012, 06:23:24 pm »
i have taken a vac from each cylinder mate. works fine. it stops so so so well. does not lock the back brakes at all.
going for mapping session number 2 soon so i'll update with a RR printout.
« Last Edit: September 03, 2012, 11:32:20 pm by lance »
Offline Karlos the jackyl
    • VW Polo
« Reply #53 on: September 05, 2012, 06:46:49 am »
That dyno printout looks weird , you have max torque before full boost ? Almost 250 hp @ 5800 is crazy ? And still 1.3 on standard head?
Please correct me if I've miss understood this!
Offline lance
« Reply #54 on: September 06, 2012, 11:04:01 pm »
not a standard head but not a big valve head and 1341cc
more mapping last night. couldnt stop it wheel spinning on the dyno during the power run though. here is the graph, it'll be a little over 260 bhp if it wasnt loosing it through wheel slip.
    • VW Polo
« Reply #55 on: September 07, 2012, 06:35:29 am »
I see , that graph looks much better   , very good output , you could easily squeeze 300 hp and a good wedge of torque with bigger blower and careful headwork.
« Last Edit: September 07, 2012, 06:44:06 pm by Karlos the jackyl »
« Reply #56 on: September 07, 2012, 06:49:18 am »
that realy is impressive power. what's it like to drive on the road with regard to traction and torque steer are you still running an open diff? Also what is the throttle response like is it very sensitive and quick to respond without making it difficult to do road car duties like parking and traffic ?
Offline Andy
« Reply #57 on: September 07, 2012, 09:58:17 am »
Nice numbers! ;D Peak power is at such low rpm for a big turbo - most of the K03'd units with same engine spec are peaking at circa 5,900rpm with the same cam, and bigger turbos are closer to 7,000rpm. The power band seems to be narrower than usual too.
Would be really interesting to see whether it's the ITBs that are making the difference, or whether your cam is timed differently.
Offline Justin14100
« Reply #58 on: September 07, 2012, 03:57:00 pm »
Incredible!
Offline Etches
  • Still got the G...
« Reply #59 on: September 07, 2012, 04:17:34 pm »
Shit man awesome power figure, good torque curve too!
