GSF main bearing set part no.
Started by Richg40, July 01, 2010, 10:07:06 PM
Richg40
I need a set of main and big end bearing asap. Is this the GSF part number for the std main bearings for a G?>   161VG0210
Richg40
gti jack
cant you cross them with gsf and vw??
Richg40
Ok, well this is the gsf description.....
161VG0210  MAIN BEARING SET-STD    PO All With Oil Hole    21.60
so.... is there any reason to buy 2 sets as it does state "All with oil hole"?
I can't see any point in the oil hole in the top half of the bearing anyway, there's no oilway under where the hole is!
Richg40
turns out they dont all have holes in, or grooves so i still need to buy 2 sets. You get 6 with grooves and 4 without. Still a bargain compared to genuine though.
Oily Fingers
whats the quality like of the GSF bearings??? i need these to start rebuild the crank etc
Richg40
they look decent enough to look at.
woody02
just put a set of gsf mains in my block, looked good quality (kobenschmidt). I had to buy two sets to get the oil hole in both halves. If you need all the gaskets for the rebuild phone rs engine supplies and speak to Nick 01233661458, he got me all the gaskets, rings big ends e.t.c
can anyone take a photo on the non-hole ones that GSF supply?  Just interested to see what the differences actually are.  As I said before the hole in the half of the bearing that goes into the bearing cap seems useless to me as there's no oil way underneath it.  But if they also don't have grooves in then that seems bad.
woody02
#10
Quote from: hayesey on July 21, 2010, 09:30:59 AM
still got my halves that are no good, il post a pic when im home from work
Richg40
Ok, so if you bought a second set you might have some spare ones with grooves in for sale?
I assume he bought two sets and then used all the grooved ones from each.
woody02
Quote from: hayesey on July 21, 2010, 07:44:42 PM
i did. only the plain ones left over.
Richg40
maybe you bought a different set to me. Mine had 6 with grooves and 4 without.
