low on performance and high idle
Started by g40Ross, May 05, 2010, 05:16:42 PM
g40Ross
hey guys had my G40 a few weeks now and it seems it doesnt pull as hard as it did in the first few days of having it! i am currently running on ordinary unleaded could that have something to do with it?
also my car idles pretty high sometimes and i read some were about removing the idle control sensor and giving it a clean may stop this! but then iv also been told it could be the blue temp sensor? can some one send me some pics of were the idle control sensor and blue temp sensor are so i can try them both!
all help will be really appreciated!
Ross
vwmk3jon
the idle control valve is under the inlet manifold behind the head. pipe going in either side and a plug.
The blue temp sensor is on the ride hand side of the head as you look at the engine. 2 plugs - 1 black 1 blue. New sonsors roughly £7 from gsf.
g40Ross
does that mean removing the inlet manifold to get to the sensor?
vwmk3jon
Easier if you do although its still possible to get at with the inlet in place but it can be fiddly.
g40Ross
its running pretty rich tooo any ideas with that?
hardchargin40
probably blue CTS again, replace them first as fairly cheap and worth doing anyway then see whats going on.  Also, as has been said, check ISV connector clean and ISV itself working ok (carb cleaner) and check CO Pot set to 550ohms.
youngprodigys
get a blue temp sensor from vag mate - the GSF ones are shit and known for being a common failure. i bought one once just to get my car running and it didnt even fit in the coolent housing!!! CHEAP SHITE!
also - check for vacuum leaks- you may have created one after giving it a lot of beans
vwmk3jon
GSF blue temp sensors really that shite? I got mine from gsf and it fit ok. Dunno if its dodgy though!
youngprodigys
they just dont last mate!
they are really are not very good at all and im sure a lot of people will back me up on this.
samg40
If its idling high have you tried adjusting the idle screw on the throttle body?
g40Ross
i havnt tried the idle screw on the throttle body no! but i dont think it will be that as it doesnt always do it just some time when i pull up at a junction or something!
g40Ross
Quote from: youngprodigys on May 05, 2010, 07:24:30 PM
were would i find vacuum leaks? ive just also noticed ive got a bit of an oil leak!
grayg40
where abouts the oil coming from? top or bottom
g40Ross
Quote from: grayg40 on May 06, 2010, 10:10:56 AM
bottom from the left of the oil filter it looks like but havent had chance to have a proper look need to get it up on axel stands!
g40Ross
oil leak fixed! replaced blue temp sensor, still idles high every now and then! went to my local vw dealers today to get an idle control valve sensor n they wasnt sure what i was talking about so have been asked to go in so they can have a look and see where it is! any one give me the correct term for this idle control valve sensor? or a part number?
Ross
